The Old Headlight Trick, Find and Fix Short Circuits Faster
http://www.crookedriverwriter.com/index.php?/Automotive-Topics/the-old-headlight-trick.html
Fuse-popping shorts in electrical circuits can be hard to locate. Younger techs have been known to incinerate a couple dozen fuses looking for a voltage short to ground, while the truly fearless among us simply install a fat jumper wire in place of the fuse, and follow the smoke from burning insulation. Neither approach will garner the "top troubleshooter" award. Here's a fasty and easy way to test those shorts safely. The procedure is rock simple and fiendishly effective |
| All times are GMT -8. The time now is 09:16 PM. |
