-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   Key fob reprogram for E24? (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/601362-key-fob-reprogram-e24.html)
E24 heaven (guest) 04-06-2011 12:25 AM
Hello There! I have a 85 E24 and I need to reprogram the Key Fob as the battery died. Do you happen to know how to do this? Thanks!
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW DME Motronic ECU Swap / Repair
Wayne 962 04-06-2011 12:25 AM
I'm not sure if the alarm systems were factory issued back then. You might want to check out my article on programming alarms here: http://www.pelicanparts.com/bmw/techarticles/101-Projects-92-Alarm-Install/101-Projects-92-Alarm-Install.htm
- Wayne
