AC issues
My 750I with 67k miles the air conditioner blow cold on the passenger side, hot on the driver side . I have both sides set to the same temperature. The car already been at the dealer for that issue twice, first time I was told they could not duplicated the problem. The 2nd time they said I was low on Freon still no problem solve. Any Ideas what could that be.
first of all tell us which built year/month your 750 is, E32, E38 etc.
Otherwise no one can help you. Have you check both heater valves and measured them? Did the dealer make a diagnosis test? The IHKA unit can be diagnosed.
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES http://twrite.org/shogunnew/topmenu.html |
