sensor specifications
Sensor Specifications
1990 735 SERIES RPM Reference Position Sensor Resistance 490-550 Ohm Intake Air Temperature Sensor Resistance Temperature(℃)..... Ohm -10............... 8260-10560 17 -23............. 2200-2700 47-53................ 760-910 Water Temperature Sensor Resistance Temperature(℃)............. Ohm -10.............................. 8260-10560 17 -23............................ 2200-2700 47-53................................ 760-910 Cylinder Identification Sensor Resistance Resistance 0.2-1.0 Kohm Air Flow Sensor Voltage (Idle To Wide Open Throttle ) Voltage 1.0-4.5V O2 Sensor Voltage Condition V Lean 0.25 Rich 0.85 and more here http://www.kovsh.com/media/library/312/Sensors%20Europe.pdf |
| All times are GMT -8. The time now is 03:13 PM. |
