Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
2003 745i wont start
I'm outta sorts! I have full power .....car cranks wont start. I have new fuel pump new alternator new Ivm. New battery.. I'm not getting. Any fuel it would seem. . I have tried everything on bimmerfest forum have found. Thought I'd try something. New. . Something. Is shutting fuel pump down. . .only code I get is a misfire and I changed plugs and coils and still nada. ..any ideas?
Old 05-11-2016, 12:11 AM
steinec's Avatar
Have you checked the SBSR module in the right b-pillar (pillar between the doors) ? This module handles the airbag in the b-pillar but also regulates the fuel. Check fuse #72 then you will have to strip the pillar to get to the wiring harness to check and see if voltage is being supplied to the fuel pump. Check out this video: https://www.youtube.com/watch?v=AeH14nUGVho
Salt & Pepper: '85 911 Carrera Targa Polar White; '77 930 Porsche Black
Old 06-20-2016, 08:52 PM
Thanks a lot! I have a similar problem!
Old 07-14-2016, 08:25 AM
