Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
Tired Member
DaddyGlenn's Avatar
2000 740iL Rusted SLS Line Replacement
This project will be an adventure into new areas for me. I have not dealt with these types of metal lines before and I am still have much to learn about these cars. So I'll be going slowly and will no doubt learn a few things the hard way.
The metal hydraulic lines that run from the pump in the front of the car to the self-leveling suspension system in the rear have corroded to the point of leaking. The task will be to free the rusted line(s) and replace them. The challenge for me is going to be getting the new lines to fit because they are not pre-bent. It will be up to me to try to match the bends of the old lines. Which means the old lines have to come out without changing the current bends.
After removing a couple of covers, here is what I am looking at:
Glenn
Daily Driver - '78 911SC RoW, Track - '85.1 944
Wife's - '00 740iL (Sport),
Support vehicle - '00 Suburban 2500 4x4
Son's - '85.1 944
Old 09-08-2017, 03:22 AM
Tired Member
DaddyGlenn's Avatar
Dwight Eisenhower once said, "Planning is essential. Plans are worthless."
My plan had been to replace only the leaking line now. Then replace others as time permitted. After further investigation of the task ahead, I believe my "plan" may indeed be, as Gen. Eisenhower warned, worthless.
Looking at where the leaking line runs and connects to the valve at the rear of the car, I am fairly certain, any effort to free the leaking line will create leaks elsewhere in the system. I may have to go "all in" on this one. Have a look:
The valve
The leaking line is the connection on the right.
And I will have to navigate this area too.
I've got some errands to run in the morning. Then I will inventory the parts I have on hand to make sure I have what I need to replace everything that is at risk. Order whatever I am missing and dive in.
But wait, there's more! I have to have this back on the road by this time next week. And there is a full week of work in between now and then.
Glenn
Son's - '85.1 944
Old 09-08-2017, 05:24 PM
Tired Member
DaddyGlenn's Avatar
Well, that was not fun, not at all.
To do this job "correctly", the entire rear end has to come out, differential, suspension, carrier, all of it. But most of us wouldn't do that. I didn't.
Spending a couple hours freeing up all the parts to be replaced was a dirty, frustrating task. Rust and dirt falling in your eyes and all over your face while trying to loosen fittings that have been rusted in place took is no fun. To get them free took soaking in PB Blaster, vise grips and careful counter holding. Eventually, it all came free. But getting the lines out was another thing. You can't do it without bending the lines and messing up the shape, even when being very careful.
You also have to deal with the rear fender liner. It cannot be removed, so it has to be peeled back to gain access.
So, once the lines are out, I did my best to restore them to their original shape. Not quite there in this picture.
Then working from one end toward the other, carefully trying to match the bends was the next challenge. Lots of odd angles and differing lengths. Then realizing that all that work has to be somewhat destroyed to get the line on the car. There is no other way. That is unless you have the suspension, carrier, etc. removed.
I took a wire brush to the valve then gave it a coat of paint before reassembly.
Before
After
Then, as they say, installation is the reverse of removal.
So far, no leaks.
Glenn
Son's - '85.1 944
Old 09-11-2017, 04:15 PM
shogun's Avatar
In case you need to reseal the regulating valve, it is relatively easy to disassemble. There is no seal kit available from BMW, so you have to find something in the net. Some pics of a disassembled regulating valve from an E32 are on my website below.
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 09-25-2017, 03:33 PM
