-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   733i onboard computer (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/99090-733i-onboard-computer.html)
michael733i 02-21-2003 08:17 AM
Hi everybody! I've got a 1984 733i, and the onboard computer doesn't work. I've checked the fuses, but their good. Any help? Also, thanks for the advice on my last problem KC, worked like a charm!
http://www.pelicanparts.com/support/smileys/pint1.gif -michael
Javier at Pelican Parts 02-21-2003 08:42 AM
It's not working as in the display is out or faded? or just nothing? If display is faded or out try removeing it and replace the bulbs through the back of it. If it's giving incorrect info might be time for a new one, unless any one out ther knows how to rebuild the inners on these things.
michael733i 02-21-2003 08:51 AM
yeah, I've got absolutly nothing comming up on the display. I don't really need it, but it would be cool if it worked. Thanks Javier. Peace.
mic
Javier at Pelican Parts 02-21-2003 08:58 AM
Pull the unit perhaps its just in the connection in the back.
KC Ron Carter 02-22-2003 12:55 AM
There is an internal fuse
There is an internal fuse, usually gets popped if cables connected backwards during a jumpstart.
http://members.roadfly.com/kcroncarter/Shark.GIF
Later,
snowman 03-01-2003 10:08 PM
The most likely failure is the display lamp. Its a $10 part, with $300 worth of labor. If you can replace it yourself its $10. No big deal, just lots of stuff to remove to get at the light.
to test check the display in the sunlight. Push some buttons. If you can see something in the reflection of the sunlight the computer is good, just the display lampl
