Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW General Discussion
Aircon Condensation Drain
Hi there, 1988 E30 325i in question here.
Does anyone know how I can access the hose that allows the condensation developed by the airconditioning to drain away?
After running the aircon for a short while water begins to cascade down the footwell. I believe that most likely the pan and drain hose are clogged up with leaves and dirt.
Is there an easy way to fix this? Is it possible to shove a wire from coat hangar or something up the drain hose? If so where can I access the drain hose?
Daniel
Old 02-22-2007, 10:04 PM
