Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW General Discussion
2015 328i GT question
I have a 2015 328i GT with 58,000 miles, and the check engine light is lit. Going into the check service menu, all appears OK. However when hooking up a code reader the message is:
Intermittent / Map thermostat, activation: line disconnection.
Does this mean the thermostat has gone bad or is there just a sensor / wiring problem? The car isn't running hot and doesn't seem to be taking longer than usual to come up to temperature which I would expect if the thermostat had failed in the fully open position.
Thanks.http://forums.pelicanparts.com/uploa...1517365989.JPG
Old 01-30-2018, 06:35 PM
