Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Mini
khule (guest)
Guest
Posts: n/a
how do you establish that the fuel pump is not longer functional .
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Fuel Pump and Filter Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 12-13-2016, 09:27 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
I would perform a fuel delivery system test. Check fuel pressure, volume and quality. if not delivery, check power and ground to pump.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
khule (guest)
Guest
Posts: n/a
My cooper s r53, engine was running properly amd I changed the feul filter, and it started cracking and the engine didn't run anymore , now the mechanic says my fuel pump is no longer functional and I need to buy a new one, how true is that
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
It's possible. But can't be sure if it is actually your issue. You'll need to test it.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Administrator
Luccia at Pelican Parts's Avatar
You can check fuel pressure, volume and quality with a quality scan tool. Testing things will always help you diagnose an issue before placing parts. It's not uncommon for your fuel pump to be working fine one day and then the next completely fail. Pumps here if needed: Mini Cooper & Cooper S (R50/R52/R53) - Fuel Pumps
Old 12-20-2016, 08:11 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
