Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Mini
Harvey (guest)
Guest
Posts: n/a
My 2007 mini s runs strong and idles smoothly. No obvious codes. BUT- it is going through a quart every 150 miles. There are no evident oil leaks. I have not yet done a compression check. Could this be the turbo oil seal? If so, how do I diagnose. Thanks - your write-ups are world class!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharger Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 12-13-2016, 10:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Remove the turbo ducts and inspect the hoses for excessive oil. Some oil residue is normal, look for puddles.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Administrator
Luccia at Pelican Parts's Avatar
Check your PCV. They're known to cause issues as engine oil consumption increases significantly if the crankcase ventilation system is defective. Read our oil consumption article here: MINI Cooper R56 Oil Consumption Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article. To check the PCV, disconnect the PCV hose on the valve cover and see if its heavily coated with oil. Definitely perform a compression and leak down test.
Old 12-22-2016, 09:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
