Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Mini
Back street garden mechanic (guest)
Guest
Posts: n/a
Hi guys. Just replaced my wife's 2007 cooper R56 thermostat . Thanks to your directions! After 3 days had a new error code: $7E8 engine, as well as : $79 A/T. When I clicked on these it stated "Engine coolant temp sensor 1",and "circuit low". But after many hrs on the web, nothing. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Thermostat Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 12-16-2016, 03:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Check if the sensor was damaged during the thermostat repair. http://www.pelicanparts.com/techarticles/MINI_R56/86-ENGINE-Coolant_Temperature_and_Oil_Pressure_Sensor_Replac ement/86-ENGINE-Coolant_Temperature_and_Oil_Pressure_Sensor_Replac ement.htm
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Administrator
Luccia at Pelican Parts's Avatar
Make sure you have the connectors plugged into the right connections. Some individuals get the swapped, which will trigger a CTS fault code. Make sure the connections are also not loose/damaged.
Old 12-22-2016, 09:42 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
