Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Mini
DIESEL DON (guest)
Guest
Posts: n/a
RENEWED FRONT PADS +DISCS ON 2007 MINI WITH NO PROBLEMS.
BUT OUTER PAD ONLY TOUCHES HALF THE DISC.
BRAKES PULL UP EVEN WITH FIRM PEDDLE
IS THIS A 'WEAR IN'PROBLEM ONLY DONE AROUND 50 MILES SINCE JOB FINISHED
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Brake Pad Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 06:45 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Can you share a photo of the problems? It sounds like the caliper is faulty.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Administrator
Luccia at Pelican Parts's Avatar
Might be getting stuck, but make sure check over your job. Is it only one one side?
Old 11-03-2017, 08:52 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
