Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Mini
J (guest)
Guest
Posts: n/a
I'm getting a P115C code. Ive put in new MAF sensor, new valve cover and new boot from MAF sensor to turbo intake. and still getting code. But no other codes. Could this engine pressure sencor have anything to do with it? . Its a 08 n56 turbo engine
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 07:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
if the intake system is free of obstructions and no leaks, the timing on engine may be off.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Administrator
Luccia at Pelican Parts's Avatar
Valve cover would've been my first note, but since you replaced it you should definitely check your timing. I'd suggest checking your throttle body. If your timing is fine, check the TB. Also, double and triple check your intercooler piping. Let us know what you find out.
Old 11-15-2017, 09:27 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
