Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Mini
Shan (guest)
Guest
Posts: n/a
Hi, i think i should just improvise my question - i am just wondering is it possible that i could have screwed up the engine timing by simply rotating the crankshaft backwards probably 180 degrees when the timing chain and oil pump chains are both intact as before?
If not, then i should start looking at the wiring and compression etc.
Would really appreciate a quick answer.
Thanks-Shan
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 07:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Yes, that can throw timing off if chain is loose.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
