Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Mini
Shan (guest)
Guest
Posts: n/a
Never mind guys, it turned out to be a stupid mistake after all. Finally had a chance to open up the ignition coils and test the ignition. Found that all plugs from the harness wire to the ignition coil had bent electrodes so the plug was not going all the way in but enough to lock into the coil.
It is highly unlikely to screw up the timing if crankshaft is rotated with the timing chain is in place but I was worried reading other forums.
Thanks - Shan
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 07:22 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Glad you figured it out. Thanks for the follow up.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
