Pelican Parts Technical BBS
Pelican Parts Technical BBS (http://forums.pelicanparts.com/)
-   BMW Mini (http://forums.pelicanparts.com/bmw-mini/)
-   -   POWER STEERING PUMP 2006 mini (http://forums.pelicanparts.com/bmw-mini/976937-power-steering-pump-2006-mini.html)
stude6@yahoo.co 11-07-2017 05:27 PM
2006 Mini. Changed PS pump and cooling fan, checked all fuses including the 100 amp, still doesn't work. how do you bench test the pump.
Luccia at Pelican Parts 11-15-2017 08:56 AM
Hello there - Did you check your alternator/is the battery light on? Any fault codes in the DME? I know when alternators pose an issue, you can have some p/s issues. Go to this article MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article and scroll to the bottom. Leave a comment and our tech should have some additional input for you.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
