Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW Mini
stude6
POWER STEERING PUMP 2006 mini
2006 Mini. Changed PS pump and cooling fan, checked all fuses including the 100 amp, still doesn't work. how do you bench test the pump.
Old 11-07-2017, 05:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Luccia at Pelican Parts's Avatar
Hello there - Did you check your alternator/is the battery light on? Any fault codes in the DME? I know when alternators pose an issue, you can have some p/s issues. Go to this article MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article and scroll to the bottom. Leave a comment and our tech should have some additional input for you.
Old 11-15-2017, 08:56 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
