-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   LSL Handlebar Kit Question (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/1004397-lsl-handlebar-kit-question.html)
hudson24 08-08-2018 08:40 AM
Hey guys - I scored an LSL kit and wanted to install and give it try. I can always go back to my original set up with barbacks, so no worries there. I looked up the older posts about this kit, but I have a question I didn't see an answer to.
If I already have the clipons bars with barback risers set up now (obviously above the triple clamp), will I still need the extended brake line for this kit? Or will my current front brake line be long enough for this LSL kit ? I ask because my current set up already had an extended line since the handle bars are already higher. The older posts I read about this kit install addressed it on bikes with the lower bar, under the triple clamp setup. Just wondering if I have to replace my line still and if so, how much longer I need before I start digging into this.
Thanks.
Hudson
00 R1100s
terrym 08-08-2018 09:44 AM
Spiegler US can probably answer your question, but you may need to know your existing line length. I recently replaced my OE lines (have RD barbacks), and they recommended going with a longer line. Not sure how it equates to the lines they ship with their handlebar kits > LSL Handlebar Conversion Kits
hellfishtat 08-10-2018 05:06 AM
I had already installed a Spiegler kit before I decided to try the LSL kit. I do not recall having to get a longer one. Let me look back through my pictures and see.
hudson24 08-10-2018 07:29 AM
Ok Thanks hellfishtat. I emailed Spiegler as well.
kpolito99 08-14-2018 02:03 PM
I am late to this thread but I also installed the Spiegler kit prior to installing my LSL setup.
Incidentally after picking up a GS as a stable mate I returned my R1216$ to using heli-bars. The LSL bars just seemed out of place last spring when I took her to a CSS event at Barber Motorsports Park.
hudson24 08-15-2018 07:00 AM
I don't see any heli-bar riser kit for the 1100s. Forgive me if this sounds ignorant, but is any of these kits compatible with the the 1100s? Thanks,
kpolito99 08-15-2018 09:11 AM
I believe that there was a kit manufactured by Suburban Machinery that would relocate the bars on the R1100S above the triple tree clamp. Sorry but it has been a while since I owned and rode an R1100S.
Alfa145V6 08-15-2018 10:34 AM
Hudson24, you can move by the bars above the yoke if you want to and have a more upright riding position. However it is likely that you will need longer brake hoses. The clutch should be okay. A chance to replace the original hoses and have fresh fluid?
hudson24 08-15-2018 11:59 AM
Thanks guys - I do have my bars above the triple clamp already and even have the barbacks. The riding position is great for most of my riding, which is 2-4 hrs each weekend. Not sure about longer trips that I am planning in the near future. That is why I thought about this LSL kit which I can always take off and put my clips/barbacks back on. Again thanks for answering my questions.
Rapid Dog 08-29-2018 11:52 AM
Only way you'll actually know about brake hose length is when you get the kit I'd reckon.
My barbacks require a longer hose at the handlebar (about 3-3.5") ONLY for bikes that came from the factory with Low 'Sport' bars an NOT ABS.
Might want to consider that if it's my 'backs you have...
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
