LSL Handlebar Kit Question
Hey guys - I scored an LSL kit and wanted to install and give it try. I can always go back to my original set up with barbacks, so no worries there. I looked up the older posts about this kit, but I have a question I didn't see an answer to.
If I already have the clipons bars with barback risers set up now (obviously above the triple clamp), will I still need the extended brake line for this kit? Or will my current front brake line be long enough for this LSL kit ? I ask because my current set up already had an extended line since the handle bars are already higher. The older posts I read about this kit install addressed it on bikes with the lower bar, under the triple clamp setup. Just wondering if I have to replace my line still and if so, how much longer I need before I start digging into this.
Thanks.
Hudson
00 R1100s
Old 08-08-2018, 07:40 AM
terrym's Avatar
Spiegler US can probably answer your question, but you may need to know your existing line length. I recently replaced my OE lines (have RD barbacks), and they recommended going with a longer line. Not sure how it equates to the lines they ship with their handlebar kits > LSL Handlebar Conversion Kits
Terry
2016 Cayman
2004 R1150S
Old 08-08-2018, 08:44 AM
'07 R1200S
hellfishtat's Avatar
I had already installed a Spiegler kit before I decided to try the LSL kit. I do not recall having to get a longer one. Let me look back through my pictures and see.
Cheers!
Old 08-10-2018, 04:06 AM
Ok Thanks hellfishtat. I emailed Spiegler as well.
Old 08-10-2018, 06:29 AM
kpolito99's Avatar
I am late to this thread but I also installed the Spiegler kit prior to installing my LSL setup.
Incidentally after picking up a GS as a stable mate I returned my R1216$ to using heli-bars. The LSL bars just seemed out of place last spring when I took her to a CSS event at Barber Motorsports Park.
You will have the rest of your life to remember. But what you have to remember depends on what you do today.
Current ride - 2007 BMW R1200S
Past bikes/sold - 1999 BMW R1100S/1994 Honda VFR 750/1989 Suzuki Katana 750/1982 Suzuki Katana GS1000SZ
Old 08-14-2018, 01:03 PM
I don't see any heli-bar riser kit for the 1100s. Forgive me if this sounds ignorant, but is any of these kits compatible with the the 1100s? Thanks,
Old 08-15-2018, 06:00 AM
kpolito99's Avatar
I believe that there was a kit manufactured by Suburban Machinery that would relocate the bars on the R1100S above the triple tree clamp. Sorry but it has been a while since I owned and rode an R1100S.
Old 08-15-2018, 08:11 AM
Hudson24, you can move by the bars above the yoke if you want to and have a more upright riding position. However it is likely that you will need longer brake hoses. The clutch should be okay. A chance to replace the original hoses and have fresh fluid?
Old 08-15-2018, 09:34 AM
Thanks guys - I do have my bars above the triple clamp already and even have the barbacks. The riding position is great for most of my riding, which is 2-4 hrs each weekend. Not sure about longer trips that I am planning in the near future. That is why I thought about this LSL kit which I can always take off and put my clips/barbacks back on. Again thanks for answering my questions.
Old 08-15-2018, 10:59 AM
Barback King
Rapid Dog's Avatar
Only way you'll actually know about brake hose length is when you get the kit I'd reckon.
My barbacks require a longer hose at the handlebar (about 3-3.5") ONLY for bikes that came from the factory with Low 'Sport' bars an NOT ABS.
Might want to consider that if it's my 'backs you have...
R11S CNC BARBACKS
Code:
https://www.gofundme.com/yr7cq-johnson-family-fund
Help Anthony!
(Yeah, I had an S once)...
Old 08-29-2018, 10:52 AM
