Mount air intake tube
My frame is missing any sort of threaded connection where the air tube mounts to the left of the box. A rubber grommet is in place at the tube but the frame shows an empty hole
The bike was actually missing the intake when I bought it and I have no idea what sort of nut or clip it used.
BMW parts fiche are of no help here.
Thanks, all
Old 04-04-2019, 05:28 AM
Intake tube is two pieces, large round end goes on top of the air filter, and ends on left side mid way back from gas take. There is a socket head cap screw that mounts it. Smaller tube slips on it and goes up left side under tank and there are two cap screws that hold it under the fairing mount.
2001 RS1100S Light. Black on Black w/carbon fiber bits.
Old 04-04-2019, 07:09 AM
tjs tjs is offline
I'm Guessing the original threaded 5mm insert that was in the frame turned, broke, etc. The BMW shop I used to work at has a Wurth threaded insert tool and various metric size inserts. A good BMW Dealer should have this. If so, you could just ride your R11S to the shop. Shouldn't take more than 5 minutes to fix. 2 cnts from TJS
Old 04-04-2019, 09:39 AM
tjs tjs is offline
Amazon has a wide variety of Nutsert tools and metric inserts.
Old 04-04-2019, 09:52 AM
RealOEM.com - Online BMW Parts Catalog
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S
'01 Boxster
Old 04-05-2019, 08:55 AM
wiggledbits's Avatar
Send a message via AIM to wiggledbits
I thought it was a through hole in frame to an insert in the nozzle bracket.
Old 04-08-2019, 09:46 AM
