Joe Joe is offline
Joe's Avatar
Send a message via ICQ to Joe
Question Need some help with measurements and temperature's
I'm mounting some electronics to the bottom of the oil cooler that protrude about a inch bellow it. I know some people in the past have smashed their front fender by mounting lights here...........anyone know how much clearance there is?
Anyone know how hot the outer frame of the cooler gets?(infrared gun)..........will it melt plastic ty-wraps?.......TIA.
77 R100RS95 A6 Quattro
http://www.joesrepairshop.com/
Old 03-06-2003, 03:37 PM
roger albert's Avatar
Hi Joe,
the very similarly loaded and located oilcooler on my similar displacement duc will not hurt cable ties, other than embrittlement after about 3 years.
roger
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 03-06-2003, 04:05 PM
Joe Joe is offline
Joe's Avatar
Thanks Roger
Now the other problem......When I had the Shock out I measured the distance to contact with a tywrap on the fork leg I seem to have a extra 1/2 " if I subtract wheel travel. I hope it's enough fudge factor............
Old 03-06-2003, 04:14 PM
Eron Flory's Avatar
I remember there being about an inch when I took this photo, shock in place with spring removed.
Oil temperatures that I have seen on various engines have been around 200-230F when run hard, above 240F (in the engine case) resulted in some sort of engine damage. The surface of the cooler should be much cooler than the oil inside the case, so I would expect the surface to be below 200F. You could buy some temperature indicating crayons if you really wanted to know.
http://www.mcmaster.com/ part# 3261K91
What type of top secret gadget are you mounting up there?
Eron
Old 03-06-2003, 04:24 PM
Joe Joe is offline
Joe's Avatar
Eron
I think you would have coil bind with the shock in before it would get that close...........right ............ I hope
Old 03-06-2003, 04:30 PM
Eron Flory's Avatar
Joe,
It is on the bump stop in the photo with the spring removed. It should hit the bump stop before it coil binds, but your results may vary depending on shock brand and preload adjustment.
Eron
Old 03-06-2003, 04:50 PM
Joe Joe is offline
Joe's Avatar
Eron
Thanks for the text I didn't see any when you posted the picture.
I'm mounting some remote radar and laser detector and jamming electronics................I've been very lucky for quite a few years....says DSL.....I'm planning a two week trip in the WV. and BRP area where they make there money on Northern boys like me. This is a pretty stealthy home brew with tie in to my wireless helmet system with music mute and different tones for 4 detector bands. Removable eye level display unit on inside of windshield also.
Wiring up 9pin Din connectors for quick removel is a real pain
Old 03-06-2003, 05:18 PM
Eron Flory's Avatar
Sounds like fun, have a good trip.
Eron
Old 03-06-2003, 05:32 PM
shannonnunley's Avatar
Joe, this sounds like a sweet setup... what kind of hardware do you need for a setup like that?
Check out BMW Forums at http://www.bmwforums.net/forums/index.php
Life should NOT be a journey to the grave with the intention of
arriving safely in an attractive and well preserved body, but rather to
skid in sideways, chocolate in one hand, martini in the other, body
thoroughly used up, totally worn out, and screaming,"'WOO HOO! What a ride!"
Old 03-06-2003, 05:53 PM
Iceblue02's Avatar
Joe when you planning to take this trip? During the ralley???
T
You can call them any time from across the nation....the Don and Mike show.........There ready to believe you.
R.I.P. #74 Kato Daijiro 1976-2003 Moto GP
R.I.P. #1 David Jefferies 1972-2003
R.I.P. #3 Joey Dunlop 1952-2000 Isle of Man TT.
R.I.P. Shannon Nunley 2005
03 BCR #125 of 200
Old 03-06-2003, 06:02 PM
Joe Joe is offline
Joe's Avatar
I'm combining some K40 Laser stuff with a Shadow360 with audio tap-offs to go into a 900mhz stereo transmitter also connected to my 20gig HD mp3 player in the smuggler I added a radar detect relay circuit to mute music when detector is triggered. If the winter ever stops maybe I'll get to try it.
Iceblue02
Thats the plan a week around the rally then I'm hooking up with a bunch of the guys from the Buell BB for another week...........
Old 03-06-2003, 06:21 PM
CarlosT's Avatar
Temperature? It's always cold up there
Old 03-06-2003, 07:04 PM
Joe Joe is offline
Joe's Avatar
Old 03-06-2003, 07:06 PM
RBMann's Avatar
Joe, does it have to be on the fairing? Could it fit on the suspension arm in front of the lower shock mount. I have a horn there without a problem.
RB
Old 03-07-2003, 01:37 AM
Joe Joe is offline
Joe's Avatar
RB
thanks but.......
I have a Ohlins shock with remote reservoir it looks like anything mounted near the steering joint might contact the reservoir at compression because of the arc of the telelever.
Old 03-07-2003, 02:32 AM
CarlosT's Avatar
RBdude thatz adding to unschprungen veight...very bad
Old 03-07-2003, 02:38 AM
dsl dsl is offline
I can't wait to see this set-up... sounds awesome, all we need now is a deer vaporizer .
Joe, haven't heard of the Shadow360, how'd you settle on that... ability to remote mount? One thing I would make sure of... that you can disable X radar monitoring on the Shadow..... 80-90% of the false signals come through X and it will render the detector useless. I've only seen K, Ka and Laser in our area.
Old 03-07-2003, 01:52 PM
RBMann's Avatar
Carlos, I worry more about the sprung weight(the spare tire around my waist).
RB
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 03-08-2003, 10:58 AM
