'07 R1200S
H7 Bulbs
I did search, I swear....
I'm tired of having to replace the low beam in my R1200S every 9 months. Beside what I can buy at an autoparts store, is there a good (bright), longer lasting bulb than 85hrs? I'd consider LED, but didn't know if the one's with ballast would fit in the R1200S bucket. I know PIAA make some, but I can't find any statement of life expentanecy.
Cheers! |
sɹǝʇndɯoɔ sǝʇɐɥ
I too would like know what folks are using / recommending. I think I'm running on borrowed time.
Mike '07 R1200S |
'07 R1200S
The Sylvania H7 I replaced them with today say they average 85hrs of life. Enough for a "normal car" to last for 1 year.
Cheers! |
I've had Sylvania SilverStar Ultra in both high and low beams for almost 2 years.
Now watch them both blow the next time I ride it... |
I’ve used PIAA for five years without needing to change, I do carry a spare now!
Phil Sent from my iPhone using Tapatalk |
PIAAs are still going strong, it appears, after a long but unspecified time.
I've been using the Silverstars in my cars for a while. I never counted the hours but those things burn out like they're on a timer. If one side goes out the other goes within a couple hours. I've learned to just replace them in pairs.
tm (R12, R11, R1) + 00 then S, S, /7 |
Are you saying the one PIAA bulb has lasted for five years or that you have not changed brands for five years ?
2004 R1100S |
Yes the same bulb for five years!
Is this a record?? Phil Sent from my iPad using Tapatalk |
'07 R1200S
Well screw paying for LED's then. Thanks Phil
Cheers! |
Kent Christensen Albuquerque '12 R1200RT, '02 R1100S '01 Boxster |
The longlife bulbs last longer because they are dimmer. That is a fact. From what I understand, the Philips XtremeVision are the best bulbs you can buy at this time.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
unsafe at any speed
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
I have a pair of H7 LEDs that I tried in my R1100S high beam. They weren't bad, but not as much light as I'd hoped for. I ended up using an H1 LED (from the same manufacturer) in my low beam, and a cheap H7 HID setup from Amazon in the high beam.
That works pretty well, as tested on a recent nighttime blast across unfamiliar desert roads in Nevada. Even the H1 low beam was OK to 50-60mph, but with the H7 HID, I was fairly comfortable at 70mph (and I'm a pretty timid rider, really cautious of overdriving my lights). So, I have 2x H7 LEDs and 1xH1 LED if anybody wants to try them. $12 each, plus shipping. |
sɹǝʇndɯoɔ sǝʇɐɥ
I heard that the bulb is a PITA to replace on the 1200s. Is this true? You have any pointers before I go and break stuff?
Mike '07 R1200S |
I'm left handed and was having a hell of a time changing a bulb on my R12S. Fussing and cussing didn't help. Just couldn't get the clip to catch. Backed up, remembered I was a lefty, switched to my right hand and Voila!! FIXED!
