diz plaz is cwazy
RIQUE's Avatar
Another gearbox different splins?
Life rewards action, He who is not afraid is safe!
A Zest for living requires a willingness to die!
BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny
BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo)
Old 05-21-2019, 05:03 AM
RBMann's Avatar
Originally Posted by RIQUE View Post
Does this mean that if I get that upgraded shaft with less spline play it could work?
Seems thats the whole idea of the improvement.
"Some specifications:
- Replaces BMW p/n 23 21 7 651 172. Fits all R1150 6 speeds
- Shaft material is harder than OE and splines have reduced backlash to further reduce wear.
- Professionally manufactured to ISO9001, API Q1 & AGMA standards by a large North American Manufacturer.
- Original prototype now at 126,000mi (203,000km) in my own machine
- By combining with the Extended Hub Clutch Disc from Beemerboneyard an additional 6mm of spline area can be achieved for a total of 12mm.
Price: $855usd insured postage included to the contiguous USA. Paypal Accepted"
Rique-
Do you have a link for the re-manufactured trans?
The input shaft on the used one that Jim Moore posted looks nasty but maybe it would clean up okay.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 100K+
* '17 Africa Twin* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 05-21-2019, 09:26 AM
Found this used tranny too. Are these splines good? Other gearboxes have them straight. Claims this is from an SBX?
Those splines are good, but those are the wrong ones. they're at the back of the transmission. You need to look at the input splines.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 05-21-2019, 09:33 AM
That one is a little hard to tell.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 05-21-2019, 09:40 AM
For comparison, here's a bad one.
https://www.ebay.com/itm/Transmission-gear-box-for-2002-2005-BMW-R1150GS-Adventure/163638822027?hash=item2619a2448b:g:mrkAAOSwddVcqmr r
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 05-21-2019, 09:55 AM
diz plaz is cwazy
RIQUE's Avatar
Here is a pic of the other side. The rear of the splines look worn or are they ok?
Old 05-21-2019, 11:05 AM
that one is just starting to go bad. Can you see the way the splines are cut / worn?
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 05-21-2019, 11:45 AM
diz plaz is cwazy
RIQUE's Avatar
Originally Posted by RBMann View Post
Rique-
Do you mean the reman input shaft? I did not post any complete reman trans
Old 05-21-2019, 12:12 PM
RBMann's Avatar
Yes, shaft. I thought it was the whole transmission, oops.
Old 05-21-2019, 09:22 PM
RBMann's Avatar
I thought Ss were the only ones that had the problem yet your link was a GS. That one looks bad.
Old 05-21-2019, 09:32 PM
All the six-speeds did. I remember hearing about it on an RT board first.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 05-22-2019, 12:57 AM
diz plaz is cwazy
RIQUE's Avatar
Here you go...
https://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/1015686-feeler-custom-transmission-input-shaft.html
Old 05-22-2019, 08:22 AM
I see you
flatbutt's Avatar
best spline thread ever
Flattbutt in Arkansas thread
'99R1100SA DDP of course
'12 M1100 mostro rosso
Old bikers don't get old by accident
equito ergo sum
Old 05-22-2019, 02:15 PM
diz plaz is cwazy
RIQUE's Avatar
Read through it all. So, its a good used tranny or take it appart and replace the input shaft. Either way you have to tear the bike to bits.
Old 05-22-2019, 05:39 PM
spacewrench's Avatar
Either way, you get to see what's going on inside the motor, that you have sort of a vague idea how it works, but you haven't actually had a reason to look for yourself yet ;-)
(Actually, although I have one of those improved input shafts and a longer-hub clutch disc, I'm not real enthusiastic about digging in. My bike is at 75k, so maybe I'm just lucky to have a good one, and if I fool around with the transmission, maybe I make things worse!)
Old 05-22-2019, 07:27 PM
diz plaz is cwazy
RIQUE's Avatar
I went ahead and purchased this transmission. Can I get some opinions on the splines. They look good to me but I'm no expert.
Old 05-23-2019, 07:28 AM
I see you
flatbutt's Avatar
They look fine to me, I can't really see if there's any slight fretting .
equito ergo sum
Old 05-23-2019, 12:09 PM
Registered Agitator
sgoodwin's Avatar
Put up a better pic of the clutch splines, it isn't a good angle. That's not the tranny from above is it (post 26)?
Old 05-23-2019, 04:51 PM
diz plaz is cwazy
RIQUE's Avatar
Here are two more pics. Yes its the same trans. I asked seller to put a wire brush to the
forward shaft splines and take pics. Looks good to me so I bought the unit for 300.
Old 05-23-2019, 07:46 PM
Registered Agitator
sgoodwin's Avatar
You do realize those aren't the splines to be concerned with, the ones on the other end are the clutch splines that go bad. That shaft isn't going to last too long with the splines starting to go bad. I would go with an extended flange clutch plate if you hope to get any life from it.
Old 05-23-2019, 08:10 PM
