Dead R1100S in Scottsdale AZ
Hello,
Yesterday I was enjoying a nice ride through Petrified Forest NP when my '98 S quit running. After checking for fuses, fuel, spark and wiggling side stand (all good), I had it towed to the dealer in Scottsdale. BTW, it was still cranking over.
I am completely at a loss to know what it is. I'm pretty sure it is not:
- Bad HES (replaced last year)
- Bad fuel pump (replaced 3 weeks ago)
- Bad ignition coil (had good spark)
Could it be a bad Motronic unit? If so, I would probably have to leave the bike here for salvage and fly home.
Any ideas or suggestions would be welcomed.
oldblue
Old 06-19-2019, 10:40 AM
If you have fuel and spark I doubt it's the motronic.
Since the pump was replaced recently my first thought was a fuel line may have disconnected in the tank (happened to me 10k after a filter replacement).
How do you know you have fuel? If just by listening for the pump it's a possibility
Old 06-19-2019, 11:30 AM
Still had half a tank left then and there was fuel in the line and spray coming from the injector when I pulled it and cranked the engine.
Old 06-19-2019, 11:56 AM
I have a "spare" single plug Motronic if you need to borrow/buy one.
2001 RS1100S Light. Black on Black w/carbon fiber bits.
Old 06-19-2019, 12:52 PM
Good test... only variable is pressure but if you see fuel it should fire.
The rest are long shots...
- Timing is off because HES plate shifted
- Motronic reset (disconnect battery)
- Mechanical issue (check compression)
Did it quit instantly or sputter and die?
Old 06-19-2019, 12:53 PM
Talking
It quit almost instantly after several stops and starts that morning. The clock reset itself to 00:00 on the 24 hour display.
(The clock reset was a nonissue as I pulled all the leftggghand fuses to check them.)
Old 06-19-2019, 01:04 PM
How old is your battery?
Old 06-19-2019, 02:22 PM
Battery is 2 years old, new BMW gel unit.
Old 06-19-2019, 03:44 PM
Dealer has it running, claims it was a blown fuse. No fault codes from the test on the Motronic.
I know they did all they could but I don't buy the blown fuse excuse. A blown fuse is a symptom not a case.
oldblue
Old 06-19-2019, 03:51 PM
What circuit was the fuse in?
Old 06-19-2019, 03:59 PM
15 amp fuse (blue) which controls the fuel pump and the Motronic. That's the same fuse I replaced 3 weeks ago when I thought i had a bad fuel pump.
Old 06-19-2019, 04:54 PM
Yet in your original post you said you had fuel/spark... the fuse wasn't blown then obviously.
Very confusing.... but you're on the road again. Good luck.
Old 06-19-2019, 05:27 PM
I know, that's why I'm so torn about leaving the relative safety of Scottsdale.
I did as much as I could in a field diagnosis to avoid the $500 upcharge on the tow.
oldblue
Old 06-19-2019, 05:33 PM
The wire in the fuse, being thin, heats up and cools down each time that circuit is used.
Eventually, it could just break, through fatigue if you like. It’s not unheard of.
But if the fuse ‘blew’ so that the thin wire is splattered, then there is definitely something amiss.
Maybe chaffed wires somewhere in the loom. Carry a handful of spare fuses until you work it out.
Intermittent faults are the trickiest to fault find. Good luck.
Old 06-20-2019, 03:15 PM
When was the last time you replaced the fuel filter in the gas tank?
2004 R1150SR - Project Touring Bike
2005 Honda RC51 SP-2 project bike
2014 Ducati Hyperstrada - for sale
Old 06-20-2019, 05:15 PM
RBMann's Avatar
oldblue
Fuses can go bad as Alfa145V6 pointed out. I had it happen one year as I went to leave a rally in CO.
The story here in post #414 and a fuse pic in #430.
2011 Top Of The Rockies Rally - 7/28 to 7/31
Story is the fuse had broken but would connect intermittently. See the right side where it is crimped. Bad fuse without any other problems since it was replaced.
Good luck.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 100K+
* '17 Africa Twin* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 06-21-2019, 09:27 AM
Happy ending update:
I made it home without any further trouble on Friday night the 21st.
Last leg of the trip took me from just north of Bakersfield CA to Port Angeles WA in one very long day of riding.
Still not sure of the exact cause of the sudden death and inability to restart in Petrified Forest NP.
My trust in this machine has been broken.
oldblue
Old 06-29-2019, 11:21 AM
I put a new Mahle fuel filter in at 160,000 km (100,000 miles). Bike currently has 188,000 km (117,000 miles).
oldblue
Old 06-29-2019, 11:26 AM
Brent
replace any of the old wire style fuses as in the photo here with
one piece fuses they dont have the failure point at the end of the wire,
and you can get them with blown fuse indicators,
ive had several of this wire stye fuse fail and they look ok.
Old 06-29-2019, 08:04 PM
