Josey's Avatar
Question Installing Speigler Brake lines
To anyone who's installed Speigler lines:
Does anyone remember what the torque requirement is for the double banjo bolt to the front master cylinder (I'm replacing the stock lines with dual braided s/s)? Is it the same as the standard BMW item (18nm)?
Thanks.
Joe Cipriano
'02 R1100SBX
If it jams - force it.
If it breaks - it needed to be replaced, anyway...
Old 03-22-2003, 06:42 PM
jgrm1's Avatar
I don't remember pulling out the torque wrench for that job. They do not take much, so I simply tightened them until they felt right.
-Jeff
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 SS/FE
Norton: 1974 Commando 850
Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy
Old 03-23-2003, 03:11 AM
pdonnell's Avatar
I just tighten away also.
Old 03-23-2003, 07:01 AM
Josey's Avatar
Speigler indicates no more than 18-20 nm. Said so right on the back of the package. If I had bothered to read the damn thing, I wouldn't have wasted valuable space and other peoples' time...
I get a little paranoid about the brakes; anything that can save my butt from a bout of stupidity (mine or a cage drivers) better be put together and working right .
Joe Cipriano
'02 R1100SBX
Old 03-25-2003, 06:15 AM
CarlosT's Avatar
How did the install go? Would you recommend Spiegler lines?
Old 03-25-2003, 10:08 AM
I installed Speiglers on my BCR. Dual front lines with straight male connector (not banjo) into the calipers and banjo on the master cylinder. Easy.
Old 03-25-2003, 11:40 AM
Josey's Avatar
Went well. Have not had a chance to ride with them, but squeezing the brake lever feels about the same as squeezing a brick...
Joe Cipriano
'02 R1100SBX
Old 03-25-2003, 12:00 PM
