-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Testing a Throttle Position Sensor (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/1062983-testing-throttle-position-sensor.html)
bullwrinkle 06-02-2020 10:38 AM
Right now, there is a bad hesitation when my 2001 BMW R1100S accelerates. I suspect there is a bad spot on my TPS, but I'd still like to verify it with a DMM. I've enclosed a photo of this 4 pin connector to the TPS. There doesn't seem to be a convenient place to insert a T-pin to back-probe the connectors. Does anyone know if there is a pigtail T- connector sold to allow me to easily get to these connectors, when it's connected up to the TPS.
Sorry for the grainy photo.
http://forums.pelicanparts.com/uploa...1591119233.jpg
Groceryrun 06-02-2020 11:14 AM
I am all in when wanting to spend money on the motorcycle.
But, if you want to save a little time and money, just use some fine wire.
Just strip the ends of some fine insulated wire , place them in the connector, and then close up
the connectors like you normally would. You will find that there will be enough clearance for the wires.
bullwrinkle 06-02-2020 12:00 PM
Thanks. I'm definitely not in the mood to be spending money, but my experience has been that the right tool saves me so MUCH time and pain that I'm pound foolish/penny wise to try and scrimp by not having the correct tool for the job.
Having said that, I'll still take your suggestion and gladly give it a try. I have some 22 gauge insulated wire lying around which should hopefully fit.
Thanks, Norman
nrpetersen 06-02-2020 02:44 PM
If you are only checking continuity and resistances w an ohmmeter, use as fine a stranded wire as you have. You don't want to mess up this connector or the mating receptable.
bullwrinkle 06-03-2020 06:54 PM
As I stated in my original posting, I'm going to be testing the voltage values to ensure it increases in a continuous way as I roll the throttle.
Roger 04 RT 06-11-2020 09:17 AM
There are two overlapping pots inside the tps. One for 0-25 degrees and another for 20-90 degrees.
Take care when inserting the fine wires. It is possible (rare) to short to the +5V in the connector and zap your Motronic.
duckbubbles 06-12-2020 06:27 AM
Playing around with my GS911 on my '03 S, I found that you can use it to set up the throttle position sensor. Mine was well within range.
Frank
wiggledbits 06-15-2020 11:55 AM
Twist Ties
Just an FYI. I have used the wire from paper twist ties. Just take some or all of the paper off, cut to desired length.
