Staintune and Chip, How Do I get in?
Now that I have been talked into installing a FIM chip to go with the Staintune Exhaust, Where can I find a tool to get into the Motronic box?
It is fastened together with a star type bolt with a pin in the center. Also, the BMW part number does not match any listed on the CBT web-sight and I can not get into the unit to see if the BMW Epron will match up? Thanks: Rob |
You need security torx. Available at most tool places
Been on many threads, so a search may yield some specifics
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
i used a pair of pliers, they are not in very tight as the lid is sealed with silicone. pry that off very carefully, take your time and it will break free easily.
repoe3
I couldn't repair your brakes, so I made your horn louder. 2009 GSXR 750 2004 Tuono 2004 R1100SBX |
Another thing to be careful of is that the lid is also sealed to the rest of the box with silicone adhesive. At least it was on my '99 Motronic. I had to do some gentle prying with a couple screwdrivers and actually break the silicone bead loose in a few spots with an extacto blade. I used a little (very little) fresh silicone when I put it all back together.
thanks all, I will get some silicone. I just returned from sears where I got the security torx $9.99 for a bit set..
Regnat populus
Greetings Robert,
The most important thing here is that static electricity can damage the ICU chip or the Motronic. Discharge all static from your hands and do not use any magnetic tools. Enjo your "S" Cheers, Robert Foster Foster Design
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. |
Robert,
When Duane at FIM pryed my ECU apart he did it with extreme care. If you are able to remove it successfully, there is no need to reseal with silicone sealant.
Lennie www.boxer-performance.com 1998 R1100S Yellow is the best (now departed from my life) |
agree with lennie, when i pried mine apart, the silicone bead was clean and made for a good seal after closing the box. it really was only installed to one side, the other just kind of holds on to it.
repoe3
I pried it apart very carefully; it looks like it will reseal. The bead looks good.
After talking to our local dyno tuner guy, I asked him if when I bring the bike to the dealer, could they see that it had a different chip in it. I was told no. He told me the BMW computer could not tell the OEM chip -V- the FIM chip. Can they tell? |
no
'89 851 '97 600m '65 Hunnybunny '05 Little man |
Just a tip: After breaking into my ECU with vise grips, I replaced the torx bit fasters with allen head screws for future accessibility.
'03 Hayabusa; '99 S - Mandarin, Staintunes, InDuct, FIM chip, SJPowerfilter, Ohlins, HID; '81 FLH -93", '00 KTM 400EXC, '96 Honda XR200 |
Regnat populus
Greetings,
FYI , I am talking here about the opening of the motronic and the seal around the outer edge of the motronic box>>>>NOT the ICU chip itself. There is an absoute need for a water/air tight seal at the motronic box. When you open it up scrape, all the factory sealant off of the mating surfaces and do not allow any scrapings to reside inside of the motronic. When you are done with the ICU chip installation, apply a small silicone sealant bead around the whole circumference of the mating surfaces of the motronic unit and install the torx and tighten. Cheers, Robert Foster Foster Design
When I got my pipe & chip from Vanderline it came with the security torx bit. The silicone split nicely after starting it with a knife.
Dave Hopkins '01 R1100SAL, KTM 400 EXC 1974 Husqvarna Vintage MX bike Infinity Q45, Toyota Tundra |
And don't worry about damaging anything by using a utility knife to cut the silicone seal. Fortunately the Bosch folks put a generous metal lip inside to keep anything (utility knife blade or screwdriver tip) from making contact with any chip or PCB board.
Grounding yourself and the ECU is a good idea. I worked with mine on top of a metal cabinet to which I was grounded as well. Can someone please post the size of the cover bolts? I wanna get some allens for next time around. |
