5 1/2 " Rear Wheel
Hi, I am new to the forum so I apologize if this has already been covered in a previous thread. I understand that you could get the 5 1/2" rear wheel as used on the K1200 as an option for the 99 R1100S's. Any idea if one from an 05 K1200 would work?
Thanks,
Kooze
Old 10-20-2020, 11:48 AM
jgrm1's Avatar
See if you can find your answer here:
Rear Wheels - All Created Equal?
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 SS/FE
Norton: 1974 Commando 850
Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy
Old 10-21-2020, 11:19 AM
Consider weighing this against how much your turning will be slowed buy going to the wider tire...you need to be hurting for rear tire traction to need to move from a 170 to a 180...
BMW R1150sR - Project Touring Bike
Ducati Hyperstrada - Mountain Road Slayer
Porsche 914-6 Vintage Race Car
Porsche 944 S3S (S3 Studie)
Old 10-24-2020, 08:23 PM
Registered Agitator
sgoodwin's Avatar
Interesting you find any difference worth noting from switching from a 170 to 180. Mostly what I found was a much better selection of tires & I wasn't riding the outside edges as much with the 180. As for flickability the tires selected determined that far more than width. And yes they stick better being wider.
Old 10-25-2020, 06:33 AM
Plenty on here over the years about wanting a bigger one....and that includes the rear wheel...
Mine came with a 170 all those years ago and 180’s were a rarity then, although I would have thought a trail of bike breakers would source one, I went the expensive route with Dymags which I have on the bike to this day.
Nope the K1200s/r wheel will not fit, I also have a K, the obvious straight away the 1100 is 4 bolt the K is 5.
I would have thought Beemer Boneyard would be the OP’s first place to ask about such, just make sure it is true they are cast slightly offset and buckle easily.
XR1000
K1200r Sport
XT660
Tiger 955
R1100s
Old 10-25-2020, 09:03 AM
Selection wise, 180 win, faster turn in, 170s, you need to really be hustling it to need the extra grip...
Old 10-30-2020, 05:49 PM
Registered Agitator
sgoodwin's Avatar
Every single time I ride, also why I've hated every sport touring tire I ever tried.
Old 10-31-2020, 05:10 AM
Thanks,
Kooze
First thing to note,..the K1200s 5.5” rear wheel (although has same 5 spoke pattern) won’t work on an R1100s . The brake rotor on the K bike is attached to the final drive hub,..
The brake rotor on the R bike is attached to the actual wheel. I’ve been down this road a few years back when I bought a 5.5” K1200s rear wheel from a closing BMW dealership & had it shipped in from another State. No returns, and it wouldn’t work. Sold it and eventually found a clean 5.5” rear wheel from an R1100s. My R11 is i-abs bike and the wheel came from a non-abs bike,.. but some micrometer measured stainless steel shims and she works perfectly.
For the record, I much prefer the wider rear wheel, huge improvement for my taste. Much more stable for higher speed twisties with a little extra counter steering.
Hope this helps.
Old 11-01-2020, 07:57 PM
