ABS pump/module failure
Is it common the have ABSpum/module failure in early 2003 R 1100 S Boxercup edition bikes? How much to replace the part?
Think of it as a chance to both improve braking & eliminate 15 lbs. of weight up high. Remove that crap & enjoy great brakes. There's an abundance of posts on removing it from the newer models which unfortunately is a bit more complicated because the speedo runs off the ABS.
Yep, done all 3 & it makes a huge difference in stopping feel with steel braided lines & turn in with all that weight up high gone. My odyssey battery was 16 lbs. vs. under 2 for the Deltran lithium battery. More like 29 lbs. gone. in my case.
Don't know which unit you have but it's about $1,000 in US dollars .
https://rhelectronics.de/repair/units/motorcycle/abs-motorcycle-am/?lang=en |
