Rear tire size
Looking at Michelin Road 5s for 2004 R1100s. Current rear tire is 170/60 17. Michelin is not offering that size. Except in a trail tire. Either a 160/60 or a 180/55 seems to be the choice. Which one fits best on the smaller (5 inch) rear rim?
Answering my own question - fergettabouttit. Continental has tires that fit. I'll get Road Attach 3 tires.
Registered Agitator
Better yet get a 5.5" wheel & run 180 tires.
https://fortnine.ca/en/michelin-road-5-rear-tire
claus IBA, 04r1100s, 11f800st, 74norton, 05f650gs auf Adlers Fluegeln getragen... |
I just bought the Michelin Road 5 Trail 170/60/17 for the 2004 R1100S .
I’m in the process of trying to get the tire beads seated. Looks like Bike Bandit might have a Michelin Road 5 170/60/17 - https://www.bikebandit.com/tires-tubes/motorcycle-tires/michelin-road-5-motorcycle-tire/p/59812
2004 R1100S Last edited by Groceryrun; 06-13-2019 at 08:05 AM.. |
Registered Agitator
They come up here & beemer boneyard occasionally. Search around & you'll find one for a reasonable price. I think I paid around $150 for mine in mint condition.
IF you gotta have 180 rear tire, one will eventually turn up (sold the one I had) but I would offer you don't need it and your bike will turn easier with what you have, it could mean some mixing of tire models, and possibly even manufacturers, but my experience has not show this to be an issue...I do prefer to keep the tires within the same manufacturer with a softer version up front and harder in rear but sometimes the tire wear front and rear just don't end up around the same mileage and I mix this up to avoid buying a new tire when I have one with say half tread left I can put on so I buy a whole fresh set next...good luck...
BMW R1150sR - Project Touring Bike Ducati Hyperstrada - Mountain Road Slayer Porsche 914-6 Vintage Race Car Porsche 944 S3S (S3 Studie) |
Yes, the ABS ring are different thicknesses. Older models 2001 and earlier I think were thicker, 2002 on, again I think that is the years that differed. I was able to use an older wheel on my 04 by adding a .192" spacer at the posts behind the ring just fine. Used SS washers matched up and maintained the required gad for sensor and runout on the ring.
Registered Agitator
There are two advantages of the 180, mostly the choice of tires multiplies by at least 100 as there is a far larger selection of 180 tires & at full boogey there's more rubber on the road particularly the edges on sport tires giving better grip & feel versus the 170's, as for quickness in transitions that changes between tires as much as sizes from what I've run.
personal opinion: ABS sucks, take 15 lbs off your bike up high & find out what great brakes you really have. |
unsafe at any speed
Yes! much better selection of tires.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
If you shop for the wider rear wheel, advice on the ABS ring above looks good, personall decision whether or not to do without the ABS...IF you find an earlier wheel and you're running ABS, you WILL need the thicker ring (4mm thick?) or shims (again, as noted above) and I've seen them on ebay and I might have an extra if they don't...IF you find and earlier non-ABS, it's pretty close to the later model that goes either way and uses the stamped steel ABS ring, your ABS will not know the difference, but maybe that's just my experience, good luck...
BMW R1150sR - Project Touring Bike Ducati Hyperstrada - Mountain Road Slayer Porsche 914-6 Vintage Race Car Porsche 944 S3S (S3 Studie) Last edited by BadToTheBown; 06-17-2019 at 01:04 PM.. |
