On a Ride
sfarson's Avatar
Can the S be bump started?
Noted the battery thread. Mine is charging now because there wasn't enough juice to turn the starter fast enough.
In case after a charge I still don't get enough power are there any kinds of push/bump starting options? I think the shaft drive prevents this? I tried bump starting the S down the slight hill of my dirt driveway but when I let the clutch out the rear wheel just skidded.
Thanks for any advice.
Old 05-23-2003, 04:26 PM
RoundelRider's Avatar
Send a message via Yahoo to RoundelRider
Angry Dead Battery
I had the same problem after my dumb arse left the key in the ignition switch. I called the friendly people at the BMW store and they said you can bump start the engine, no problem. He suggested that I put the bike in 2nd or 3rd gear and roll down a nice hill. My personal attempts were unsuccessful, and I stuck it back in the garage and charged the battery properly. Good Luck
John
John
'03 R1100S Prep RIP
Old 05-23-2003, 05:05 PM
dsl dsl is offline
I think I remember being able to jump start my old air head using 2nd gear. I wonder, though, how much all the electrics on a modern bike need to be juiced up before they'll allow ignition. IE, full pump, motronic, fuel injection etc.
I thought I've read here that you can jump the bike off a car (not running) by using the positive terminal on starter motor (being much easier to access than the battery). Or is this still too much juice that risks frying your electrics?
Steve, don't you have a number of beemer bike that you could jump from?
Old 05-23-2003, 06:00 PM
hwy1&17's Avatar
I have a long paved hill outside my house and I tried bump starting in most gears 1,2,3,&4 with no sucsess. took two of us to push it back up the hill.
needless to say I had an outlet put on for easy charging.
Eddy would go
05 999
02 phoenix gray R1100SA (sold)
00 black TL1000R (sold)
dodge cargo van with alot of stickers (dodge sucks)
AFM #912
I jumped my S, 4 wheeler, and previous bike using the cage. No Problemo!
John
John
'03 R1100S Prep RIP
Old 05-23-2003, 06:22 PM
webby's Avatar
jump starting
As I understand a translation from the German boxer site (boxer-forum.de).....
If you remove the starter motor cover you'll find a heavy duty cable terminal to which you can attached the positive end of the jumper cable directly.
You attach the negative end to a "substantial" frame element and off you go.
Is this correct and if so has anyone tried this method?
not up a mountain
'02 R1100S "Mandarin/Silver"
'98 K1200RS "Yellow taxi"
'91 K1 "Red/Yellow"
'08 Honda Civic Type R
Old 05-23-2003, 09:49 PM
Red face
I seroiusly thought about it when my batt was kaput. Being a mechainc i look for things like that but I played it "safe" by removing the side panels and going directly to the battery. At the same time I installed my Induct, and SJ filter; so it wasnt a total waste of time. Its still a pain in the ass to get to that battery.
John
'03 R1100S Prep RIP
Old 05-24-2003, 04:50 PM
On a Ride
sfarson's Avatar
Tried the battery again after charging all night. Dead. Doesn't look like bump starting is much of an option. The jump using the starter looks interesting but I'm hesitant.
Soooo... I've bought a battery, and mechanic challenged Steve here is going to try to swap batteries. See other thread.
Thanks everyone for your thoughts.
Old 05-24-2003, 08:21 PM
GUS GUS is offline
I know how you feel guys.I spent a good hour trying to bump my bike from cold when the battery died on me.It aint possible!Its a big ****off twin,thats why honda left their starter motors on there SP 1 superbike.
GUS
Old 05-25-2003, 06:54 AM
CarlosT's Avatar
There are too many subsystems on the S to try to bump start a dead battery. Steve it sounds like you got other problems. Are you sure that it was charging?
Old 05-25-2003, 07:27 AM
Ted in Evanston's Avatar
I had to bump start my K12RS, during a trip, when the sprag clutch on the starter failed. It came to life, using 2nd gear. Must've been lucky. It did not get shut off for the subsequent fuel stops that day!
Regards,
Ted in Evanston
'03 Tuono
'00 K12LT
'00 K12RS (was)
'99 Triumph TT
Old 05-25-2003, 09:45 AM
Rattus's Avatar
Roll starting the S isnt easy but it can be done. If you're by yourself, its hard to get enough speed up so when your release the clutch the engine starts - it helps to be fit if you want to try this. I've had best success down a slight hill with another person pushing (2nd gear). Having weight over the rear wheel is a good idea to avoid the skid. Suffice to say I'm a fan of battery chargers now.
Regards, Rattus
KTM 625 SXC in my grubby hands. R1200S in my Heart.
A man can fall many times in life but is never a failure until he refuses to get up - EVEL KNIEVEL
Old 05-25-2003, 05:05 PM
Funnily enough, when I went to go for a ride yesterday, my battery was flat. I haven't fired the bike up for a month, it has been getting down to 4 degreesC regularly overnight lately and it is almost fives years old.
Thanks to information from this BBS I tried jump starting directly to the starter motor - no problems!! The hardest part was trying to get the Allen key in position to remove the starter motor cover. It is bit of a pain.
I will be installing an Odyssey battery in the next week or so, along with my idea ( never got around to it) of a short length of 6mm cable from each terminal ending up under the seat, so that one can easily jump start the bike when (sometime) in the future the battery is flat once again.
Cheers
TREVOR
1998 Red S
You are never too old to have a happy childhood!
A Throttle works two ways - only one is FUN!!
Old 05-25-2003, 05:49 PM
Rattus's Avatar
Hi Trevor - I suggest you have a look at this trickle charger that Jenny and I have used to good effect. Note the leads that stay permanently on the battery. But making a "crossover" cable we can jumpstart our bikes easily from the other bike or an external source, or just trickle charge it if need be.
http://www.roadandrace.com.au/battery_charger.htm
Regards, Rattus
Old 05-25-2003, 06:06 PM
fiery's Avatar
Cool Batt. Charger
Cool tip Rattus. For $AUD 65, sounds good.
Old 05-25-2003, 11:45 PM
Bumble Bee's Avatar
An easy way to either top up your battery or kepp it charged for periods that the bike is unused is to purchase a 240VAC to 12VDC (or 110VAC to 12VDC) transformer / power supply available at TANDY or the like ensuring the AMP rating is no more than 500milliamp or 0.5 Amp. Attach a male plug of your choice to the end of the lead and a female plug to a short lead then dirrectly to your Battery. The current from this type of power supply is not enough to do any damage and will keep your battery voltage at a usable state all times. I have used this system on many bikes and cars for years all with positive results.
Bumble Bee
Old 05-26-2003, 03:38 AM
I do the same thing B Bee.My 1999 s battery is in great shape. I have used this method for years and usually get 5-6 yrs from a battery. Radio Shack $9.99! for 500 ma 12v charger.
Old 05-26-2003, 06:56 AM
RBMann's Avatar
I would lose battery water over time with the constant rate charger. What a drag on the S. I do not have that problem now that I use a Battery Tender.
RB
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 05-26-2003, 07:20 AM
Hello,
I bought one of those $20 battery trickle chargers from Wal Mart last fall and attached the leads to an aux plug I got from A&S cycles. This I just plug into the Aux plug below the seat. Kept my battery good all winter.
Jon
BMW.....There is no substitute!
'99 R1100S, '92 325is
Old 05-26-2003, 08:04 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Battery Tender & accessory plug are a given I presume.
Battery Tenders are cheap at the right online store although the accessory is another $50-$60. I am still on my first battery with it tho.
wallyscycleworld.com
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 05-26-2003, 08:21 AM
