Exhaust Stud
Who has had the pleasure of removing a sheared off an exhaust stud from the cylinder head? And what did you find the best method to be?
Thanks - Jay
2020 R1250RS 2014 Ducati Monster 1200S 2005 R1100S BCR 1996 K1100RS 1984 Kawasaki GPz 1100 |
Never an exhaust stud but many similar broken studs. Is there anything left to grip on to or is it flush? If close to flush likely will require you to file the end flat if you can centre pinch the middle of the stud, drill with a centre drill and then carefully drill for for use of an extractor tool, my preference would be something like the Ridgid 35535. Keep wet with penetrating oil and some heat twice a day for a week or so then warm up area prior to trying to extract. What size is that stud about 5mm or 6mm?
87 930, Last edited by 908/930; 12-26-2022 at 02:42 PM.. |
Yes…the parts fiche calls it an M8
You can use the larger extractor the Ridgid size 2 #35540, will still need to drill carefully. If there is any stud to grab on to a small pipe wrench could work, but don't skip the penetrating oil.
Did it rotate at all prior to breaking? If it galled the threads thats a larger problem, still possible to remove though.
87 930, Last edited by 908/930; 12-26-2022 at 02:48 PM.. |
With a BMW exhaust stud, you better save your time and skip the extraction phase to go straight to the helicoil repair.
R1100S / VIN ZA84895 |
