JoeAsheville's Avatar
Question Saddlebag question
Hi there. New forum member here...from Asheville. Yes, we had Rudolph recently, yippee.
If a R1100SA does not currently have brackets for the hard bags, and I wish to put them on, do I need special rear bodywork to fit them? The upper forward attachment point seems to delve into the bodywork somewhere in all the pictures I saw...I can't get a clear view of the area.
Thanks for all replies.
Looking for a good shape R1100SA!
Old 06-04-2003, 04:26 AM
Used to ride a motorcycle
JustAnotherSquid's Avatar
Re: Saddlebag question
No.
'01 BMW R1100S | '03 Suzuki SV650 #555 "Princess" | '07 Suzuki SV650 #555 "Pigpen" | '16 BMW G650GS
Old 06-04-2003, 04:27 AM
Welcome Joe. Been in Asheville long? I grew up in the area, just the other side of Old Fort and have several friends in the Asheville area. Attaching the bag mounts is a very simple operation and as Justanothersquid said, does not require any special body work. I'll see you on the parkway sometime. Frost Blue 01 R11S.
Old 06-04-2003, 05:23 AM
The brackets consist of four pieces. Two that mount on the back under the seat. There are four bolts that hold them on. There are two addional pieces that are used to stablize the bags that attach under each passenger foot peg. It will probably take you 20 minutes to put everything together and attach it before you are ready to ride off with BMW system cases attached. The only real issue is the cost. Once you get over that you are all set. Once the brackets are in place they act as nice hand holds for your passenger (you know that really hot blond that was scanning your bike thinking how nice the subtle vibration of the twin motor will feel between her legs.)
Good luck.
04 R1100SA (Pacific Blue metalic)
99 R1100SA (black) -- Totalled
Old 06-04-2003, 06:04 AM
Good luck.
Ohhhh yeaaah. Thanks for the verification that I will not need special bodywork (other than the passenger's) for the bike.
You've just reminded me why I enjoy motorcycles so much in the first place.
Old 06-04-2003, 09:01 AM
Iceblue02's Avatar
Bags
I just put on my brackets this morning. Took me about an 1hr. Take off the Charcoal canister. Makes it a little easier to get the bolts in the lower attackment point. Also the bolt that is under the seat is a little tough to get on. You have to tweek the bracket a little to get the Nut on. I used a handy little clamp to pull the bracket up tight to get the nut started. I left the rear foot rests off and attached the lower brackets with the foot rest bolts. No problems.
On the left side of the bike, take off the small heat shield and dont relpace it when you put on the bracket. If you order the brackets you get a booklet to show install instructions.
T
You can call them any time from across the nation....the Don and Mike show.........There ready to believe you.
R.I.P. #74 Kato Daijiro 1976-2003 Moto GP
R.I.P. #1 David Jefferies 1972-2003
R.I.P. #3 Joey Dunlop 1952-2000 Isle of Man TT.
R.I.P. Shannon Nunley 2005
03 BCR #125 of 200
Old 06-07-2003, 10:57 AM
Raven's Avatar
Please tell me you didn't put the cannister back on!
Old 06-11-2003, 05:32 PM
