Hi Guys,
Looking for a set of end cans to fit onto my Zach "Y" piece. What make do you recommend and where from. Ride Safe -- Biff
Laser street muffler...by far the nicest finished and they hang like the stockers...prolly about $500-600 US Dollars.
Cheers Carlos, I'll see if I can find a few pic's of the Laser
Biff |
Used to ride a motorcycle
Los,
Is this the model to get? 96.7005 v3.1? ![]() Once the TL is gone I might have to spring for this.
'01 BMW R1100S | '03 Suzuki SV650 #555 "Princess" | '07 Suzuki SV650 #555 "Pigpen" | '16 BMW G650GS |
Yikes ... I don't like the "Remove Centerstand" part. I'd rather have the centerstand + stock exhaust than aftermarket pipe and no centerstand.
You don't lose the centerstand. The cans are available by themselves so you could technically put the mufflers on with the stock catalytic on. You don't need the Y-pipe cat eliminator in order to put on the Laser mufflers.
Yeah the whole kit is pretty cool though. This is the exact kit that Tim got for his DickDogRed S. I'll let you know but I don't think that you need to remove the centerstand. |
Regnat populus
Centerstand
Greetings,
The Laser PN # 96.7005 "System": Twin Oval "INOX" stainless cans, sport collector and the Laser PowerChip are a winning combintion. A well tuned combination, that has the benifits of a smoother running engine, more powerful performance across a wider powerband, and it just bolts in, a simple installation that you can do yourself. Oh, and do follow the instructions fully>>>DO remove the DB-Killers at the outlets...."for racing only"....sounds sooooo good. You can always put them back.... And the centerstand can stay! Happy Memorial Day! Cheers, Robert Foster Foster Design FosterDesign@att.net Last edited by boxercup; 05-24-2003 at 05:49 PM.. |
Regnat populus
Greetings,
BMWMIKE, JAS>>>>The Laser PN# 96.7001 Twin Oval slip on muffler will slip right on to that Zach cat eliminator. Get the Paser Powerchip to compliment the setup PN #87.7004.Y for early Motronics>>>>PN # 87.7006.Y for motronics after Sept, 2000 production. You will like this set-up! Cheers, Robert
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. |
Thanks lads you've been a great help as usual. I'll have a look at the Laser.
Biff |
Endurologist
Center stands are bad. Heavy. Lower topspeed and acceleration. Centerstand is for Honda Deauville.
The Latest is the Greatest '09 HP2 Enduro - '06 m620 - '08 Koga XPM-M CB200, XS750, GL1000, GL1100, R80RT, 2xK75S, F650, RF600, ZF600R, 750ss, 888corsa, 900ss, 3xR1100S, K1200R, R1200S, R1200GS |
Looks as if this will fit on the twobrothers cat eliminator. Is this true? regards David
"all of us are ignorant, just about different things." will rodgers |
