blakebird's Avatar
front brake calipers
Was taking off the front wheel tonight to get the tire changed tomorrow. The RSV had hex cap bolts holding the front brake calipers....I never dreamed I'd be looking at a torx bit!
Classic....the one kind of tool I don't have many of (and it's never hung me up before!).
Can someone help me out with the Torx bit size, and if possible, a torque spec?
I'll be I can get it here hours before any of the local BMW shops are open.
Blake
Old 07-08-2003, 10:53 PM
johnnydanger's Avatar
My S has the proper sized torx wrench in the toolkit under the seat.
Good luck.
Old 07-08-2003, 11:32 PM
blakebird's Avatar
...ah, the legendary BMW toolkit. I'm not used to having a toolkit complete enough to contain anything Torx.
Excellent.... and thanks!
______________________
Multistrada | R1150GS Adv. |KDX220R
Old 07-09-2003, 04:27 AM
repoe3's Avatar
but since they need to be torqued, would recommend a run to sears to get the right bit and you will be good to go.
repoe3
I couldn't repair your brakes, so I made your horn louder.
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 07-09-2003, 04:29 AM
blakebird's Avatar
yep..... I need a set of Torx anyways, the chore will be finding them in 1/2" drive to fit my Sears Digitork.
At least I can remove the wheel for now and get it to the shop for the tire change.
Old 07-09-2003, 06:10 AM
repoe3's Avatar
if anything you should be able to order a set easily online. but i think mine is a 1/2" could be mistaken. it was a few bucks just for the one torx socket.
repoe3
2009 GSXR 750
2004 Tuono
2004 R1100SBX
Old 07-09-2003, 06:20 AM
roger albert's Avatar
If sears doesn't have it online, then the online versions of Grainger, MSC, and SnapOn all do.
hth
roger
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 07-09-2003, 06:37 AM
