License Plate Lamp Bulb
Mine's out.
Is this such a weird one that it's gonna be dealer only?
Ride well. Ride safe. WEAR YOUR GEAR!
-Jack Price
Glendale, CA
03 BMW R1150GS
01 BMW R1100S (sold)
01 KTM Duke II (for sale)
Old 09-05-2003, 03:16 PM
EZ-RIDER's Avatar
Any auto parts store has them they come in a two pack for around $3.00 to $4.00 dealer wants around 10.00 each.
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 09-05-2003, 03:26 PM
tvrla's Avatar
I've also found them at the regular parts store. Seems like they only last a couple of weeks, though.
I've been wondering if there's some sort of LED replacement that might be a little more rugged.
Old 09-05-2003, 04:04 PM
Do you guys have a part number for those?
None of the Sylvania ones at a local parts store had the offset pins like my original one does.
I wonder if the dealer ones ae $10 because they actually last a while.
Kodak plant burns to the ground. No film at Eleven.
-Jack Price
Glendale, CA
03 BMW R1150GS
Old 09-05-2003, 04:32 PM
Hang Ten !!!
Mine is out and from the look of it it's been out from day one (assembly error). The rubber boot was split and inside I found much road grime along with the pieces of the broken bulb. My fix was to toss the whole thing and pull the wire up through the subframe and coil it up under the seat., which makes taking the license plate bracket off for the track 3-screw easy.
Old 09-05-2003, 04:38 PM
arbik's Avatar
Send a message via AIM to arbik
I might be able to rig somthing up with a couple of LEDs...
Jack; give me a hauler when the goods come in, and I'll bring my LED-treasure box down, and we'll make a bulletproof light on that puppy..
I bet mine's out too...I'll go check right now!
-arbi
2004 R1100S-BCP - RIP (2-1-04)
2004 R1150R Rockster; NASA approved
Old 09-05-2003, 08:18 PM
Joe Joe is offline
Joe's Avatar
Send a message via ICQ to Joe
A pair of high output white LEDs in series with about a 200 ohm resistor should work fine .........4 years on the one I made
77 R100RS95 A6 Quattro
http://www.joesrepairshop.com/
Old 09-05-2003, 08:55 PM
