Olaf's Avatar
UPDATE: Another Rear End Bites the Dust
Well, you can add mine to the list of rear end failures
2002 Prep with only 10,000 miles on it. You grab the rear tire at 3 and 9 o'clock and guess what it moves and you hear a "clunk"
Goes into the shop today for the rear end and warped front rotors. I have had 7 BMW's and it just seems that the newer ones certainly have more problems then the older ones I have had.
Sorry, I just had to vent.
Jon
Old 09-22-2003, 08:06 AM
roger albert's Avatar
Sorry to hear it Jon,
Post back when you get a chance and let us know if the play was in the rear drive carrier bearing or the rear pivot. Seems that both happen, with the pivot being a moderately more frequent reason (maybe 2:1?)
good luck
roger
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 09-22-2003, 08:52 AM
Olaf's Avatar
Roger,
I will post back and let everyone know what the outcome is. it most likely will not be finished until the end of the week.
Thanks,
Jon
02 Prep (toasted), 75 R75/6, 03 F650GS
Old 09-22-2003, 09:25 AM
Olaf's Avatar
Well, it ended up being the pivot bearing. It is already replaced.
Still waiting on if BMW is going to cover the rotors. the RHS is 2.5 times more warped then the LHS. Did not get the exact figures.
Ragards,
Jon
Old 09-24-2003, 08:59 AM
I spoke with some riders to did Deals Gap evening last and they mentioned several "K" bikes with rear end failures afterward. I cannot confirm this as truth or rumor however. Perhaps the later model BMWs cannot handle the more aggressive rides. Or maybe they are just being pushed harder that BMWs have traditionally been ridden.
No expert here, but would be interested in other's view.
The great modern mistake " The mind equals reason and the heart equals emotion"
Old 09-24-2003, 09:54 AM
My view - unexceptable! Hopefully BMW will cover both the rear and brake issues. One would only hope.....
1984 Porsche 911 Carrera
2002 BMW R1150RT
2013 Audi A4
2020 Ford F150 4x4
Old 09-24-2003, 10:12 AM
captainasty's Avatar
The KLT's have a high rear end failure. The KRS's have very little. The overloading of the LT is the problem.
Old 09-24-2003, 10:27 AM
Olaf's Avatar
The Rear End will be covered. If the rear end has already had issues at 10,000 miles I have a feeling this will not be the last one:-(
I feel the rotors should also but we will see.
I know some others have been and I plan on doing my best to get them covered.
Jon
Old 09-24-2003, 10:40 AM
Olaf's Avatar
Just got a call from my dealer and BMW is also going to cover the warped rotor. It was the right one they said.
So they are going to put a new RHS rotor on. I have 10,000 miles on the LHS! Am I going to run into any problem with having 1 Rotor with 10,000 miles on it and the other one brand new?
Thanks,
Jon
Old 09-25-2003, 11:56 AM
That should offer no problem.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 09-25-2003, 12:07 PM
Olaf's Avatar
Thank for the response Roger!
Jon
Old 09-26-2003, 10:41 AM
Raven's Avatar
The early Ks have a very high rear end failure rate. So high that it has spawned several law suits. BMW failed to make good on a known defect.
I have over 42K on my rotors and still straight! It is odd that yours failed so quickly!
Old 09-28-2003, 02:37 PM
Olaf's Avatar
Raven,
I also am very surprised that they warped so early. At least BMW replaced one of them. I went out and rode it Sat. and it is night and day difference , but the LHS is also a litle warped but not really anoying yet.
Jon
Old 09-29-2003, 05:25 AM
I read this thread and just checked mine and there is side to side slop when grabbing the wheel at 3 & 9 oclock. There was none just a few weeks ago.
Mine is at 14K miles; does anyone venture what repairs cost?
Old 09-29-2003, 10:42 AM
