-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   IBMWR zero=zero procedure TPS voltage (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/134524-ibmwr-zero-zero-procedure-tps-voltage.html)
pwillikers 11-06-2003 09:02 AM
I love you guys.
So... to answer my question, the voltage setting on the tps is independent of the motronic version. We have the same settings, .37~.4, as the older R's.
And, the higher the reading, the richer the mixture - for very small throttle openings where surging occurs. But, stay below .4, the approximate value at which a fault is registered. I think I'll set it at .395 (per Roger) and see if that cures the surging.
MarkC 11-06-2003 11:27 AM
From my personal and unprofessional experience here's a couple of tips I learned.
1. Attach the neg lead from the Digi-Volt meter to one of the two 'TPS retaining bolts' (or that little brown ground wire under the throttle body) for a good consistent ground (I've gotten different values when I attached the ground lead from the Digi-Volt meter to other parts of the bike).
2. Read the voltage and adjust with the bike's engine running. I found that with the engine not running, the voltage reading would start at .330 then move up to around .350 ~ .370 pending on how the battery is. So to get a consistent voltage reading, I have the bike’s engine running.
My S from the factory was set to about .330 volts, read with the engine running. Mine is now set at about .360, again with engine running.
MarkC
roger albert 11-06-2003 12:27 PM
Hi Paul,
I'd second MarkC's good advice on measuring with the motor running.
Let me clarify what said (or meant to say) I've had good results up to .395 or a little more, but generally like something a bit lower (which also helps keep idle realistically low) .375, or even down towards Mark's .360 can work well. I'd be tempted to start around .375 and then play a bit. Good luck
Roger
