Rear Brake Reservoir Relocation
I asked the same question in a post about brake pads so it may have been missed. So, does anyone know of a kit that will relocate the rear brake reservoir away from a hot Staintune pipe?
Jim '18, Ford F-150; '07, Lexus IS350; '01, R1100S; '80, R65; '76, Honda CB750 Four; '73, Ducati 750 GT; '70, VW Beetle; '65, BMW R60/2; '64, Triumph Bonneville; '64, MV Agusta 125 GTL; '60, BSA Gold Star; '55, R25/3 |
I don't know of a kit but the spring clip that holds the reservoir is offset. Pop out the reservoir, drill out the rivets that hold the clip, flip it 180 degrees and re-rivet, clip the reservoir back in. This moves the reservoir at least 10mm away from the pipe and it still sits comfortably inside the rh body trim. Takes about 10 mins.
David |
i never bothered to do anything other than take a cheap black wrist sweat band, applied some of the foil tape that came with the staintunes and then covered it with the wrist band. it is not like it is visable, but do what you feel comfortable with.
repoe3
I couldn't repair your brakes, so I made your horn louder. 2009 GSXR 750 2004 Tuono 2004 R1100SBX |
i popped the resivoir out and put a cresent wrench on the bracket and bent it out from my pipe. popped one rivet and had to replace it.its pretty easy to do.wayne
The universe operates on two governing principles, one is Reason, the other is Rhyme, which is very close to rhythm. Our culture is fixated on Reason, the Sea is fixated on Rhyme. |
