Dont taunt happy fun ball
AndrewA's Avatar
Send a message via AIM to AndrewA
Newbie question - Lighting
Should the brake light glow when the other lights are on ? ie as "running lights ?
I noticed that the brake light bulb is dual filament. Well, only one filament lights-up (when the brakes are applied).
I believe that the bulb is installed properly.
Thanks in advance.
Old 12-13-2003, 05:52 PM
s-addict's Avatar
Send a message via Yahoo to s-addict
andrew when you turn your key to park does the tail light come on? do you have a red light that stays on the dash board?try a new bulb.red light staying on after self test indicates tail light failure
The universe operates on two governing principles, one is Reason, the other is Rhyme, which is very close to rhythm.
Our culture is fixated on Reason, the Sea is fixated on Rhyme.
Old 12-13-2003, 06:29 PM
AndrewA's Avatar
SA,
When I turn the key to Park I have NO lights anywhere (tail/licence/dash..) Nothing turns on.
Also, I just noticed that the running light at the headlight does not work either. WTF
I checked the ignition switch to see if there are any loose leads there...It look fine.
Old 12-13-2003, 06:45 PM
s-addict's Avatar
turn wheel toleft or right turn key past lock to "P"setting should have lights
Old 12-13-2003, 06:48 PM
Joe Joe is offline
Joe's Avatar
Send a message via ICQ to Joe
Andrew..............some of your lighting relays might be up at Bear mountain still .............that head-shell took a good wallop
I think theres a parking light relay make sure it's there if fuses are ok
77 R100RS95 A6 Quattro
http://www.joesrepairshop.com/
Old 12-13-2003, 07:23 PM
s-addict's Avatar
headlight wont come on in park only little flashlight looking bulb.sstick new bulb in tail light first.check easy stuff
Old 12-13-2003, 07:39 PM
AndrewA's Avatar
Joe,
The bike is actually all together. I had an opportunity to ride it a couple of weeks ago just before we got 30" of snow ! I'm just down to some small odds and ends to finish-up before it's 100 % again. I'm sure that these last details will take me through to April to figure-out.
The fuses, ignition connections, and bulbs all seem to check-out. I'll strip the bike down tomorrow and check for bad wires.
It is entierly possible that I have some bad relays. They all look prety good though - other than the large "Indicator Damping" #4 relay, which got crushed but still looks whole (what is that for anyway ?).
SA - I picked-up some bulbs from AutoZone. Is it possible that I got the wrong bulbs ?
The counter guys were not much help. Neither of them work as they should (the bulbs, not the counter guys)..ie only one filiment working.
I got nothin in "P" from either the the headlight/parking light or the tail light, or any lights for that matter. When the key is turned to "R" (run?) I get the head lights, licence plate lights. All turn signals/flashers/high beams/motolights... work.
Do I have more than one problem here ?
Thanks for the help !
Old 12-13-2003, 08:20 PM
s-addict's Avatar
like joe said since you don't have front and rearin "park" it may be a relay. checking manuel fuse #2 controls the following:rear light parking light license plate lite.you did check fuse right?rear bulb is12v 21/5w parking light is 12v 5w.pull out parking light and check it after you check fuse but if fuse was blown you would not have license plate light.
Old 12-13-2003, 08:45 PM
AndrewA's Avatar
It is a good day !
Saddam was given a beard trim courtesy of our brave American forces, and I solved my parking light issue.
Apparently, there is a small, thin gray wire that goes into the headlight plug. This wire was shorting in the Romex plug.
All lights work now !
Thanks !
Old 12-14-2003, 07:06 AM
