The Sea Dog's Avatar
Oil blowing out of top of head onto fairing
I've searched the archives but couldn't find anything similar. Has anyone experienced their bike blowing oil out of the top of the cylinder head into the fairing ?
I've re-torqued the heads just in case, but I'm not convinced that it's that gaskets. The heads were recently fitted with helicoils for the header pipe studs as the old ones had corroded solidly in. I'm hoping that the machine shop have not drilled an oilway :-(
Anyone come across this before ?
PAul
Keep it sticky side down
Cheers
PAul
On a clear disk you can seek forever
Old 01-21-2004, 03:44 PM
roger albert's Avatar
Never heard of that, so far. Just where exactly on top of the heads? Near the header? Along the head/cylinder seam?
Or the head/valvecover seam? Bottom clean?
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 01-21-2004, 04:14 PM
oil blow
Hey Roger
From my quick initial inspection it's almost as if it's blowing out the gap in the middle of the cyclinder head cooling fins, just above the spark plug tunnel.
I'll look closer tomorrow.
Cheers
PAul
Cheers
PAul
Old 01-21-2004, 05:29 PM
shovelstrokeed's Avatar
Crunched or missing spark plug tube seal.
Remove valve cover, inspect, replace.
Ed
Sometimes you just gotta!
02 1100SBX, 00 VFR 800, 99 540i-6, 94 1100RS, 91 Guzzi LeMans 1000, 85 K100RS turbo, 78 R100S, 53 Panhead
Old 01-21-2004, 06:53 PM
EZ-RIDER's Avatar
Hey Sea Dog;
I agree with Ed, Spark plug tube seal!!!!!!!!!
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 01-21-2004, 07:02 PM
tominator's Avatar
Send a message via AIM to tominator Send a message via Yahoo to tominator
Dealer servied mine and I had oil blowing out. That spark tube rubber slipped off while reinstalling the rocket cover, removed cover and installed fresh donut. Fixed the problem. Always make sure its intact before reassebling cover.
No biggie!
Tomas
If it has two fun bags I'm in!
2003 R1150RT, 2006 Cadillac CTS,2000 GMC Sonoma Slammed, 81 Harley Davidson Shovelhead Stroker, Supportive Wife,Jack Russel Terrier and a 18 year old who things he's 23.
Old 01-21-2004, 08:01 PM
Spark plug seal
Hi guys
Thanks for the replys, I've looked at the manual and don't see and exploded diag that has that showing, just to clarify would that sit in the recess at the base of the cylinder head ?
Cheers
PAul
Keep it sticky side down.
Cheers
PAul
Old 01-22-2004, 12:03 AM
Nope,
Remove the valve cover, its dead center between the pushrods and about 1.5" down. Black (rubber) torus that slips over a hollow pillar in the head.
Hang on a minute, I'll check a parts drawing, OK, its clearly pictured on page 11.18 of the 1100S repair manual.
Ed
Old 01-22-2004, 02:23 AM
Diag
Hi Ed
That's what I meant but didn't say very well I've ordered a couple of them up and I'll fit them when they arrive.
I did look at that page in the manual, but can only imagine I was too tired to spot that great BIG SEAL in the middle of the page, what a schmuck....... Thanks to all
Cheers
PAul
Cheers
PAul
Old 01-22-2004, 03:29 AM
MarkC's Avatar
Location: While a member here: Japan - Germany - USA - Curently: UK
Re: Diag
Originally posted by The Sea Dog
Hi Ed
One thing I have discovered is that some of the setting sin thr manual appear to be incorrect, for instance the clutch plate bolts it lists as 40nm, which sounded pretty high. I torqued up the first one and sure enough it sheared well before 40nm. Spoke to a specialist who suggested around 19/20nm, the same as the K1200. They seem pretty good on that.
Anyone else found that ?
Cheers
PAul
Hi Paul, I also just replaced my clutch on my S (clutch spline damage, but the job was originally to replace a leaking input shaft seal on the clutch side). My BMW repair CD (page 145) list 40Nm for the flywheel-to-crank bolts, then turn an additional 32 degrees. The clutch housing bolts (6 of them, think they are 10mm heads) are listed to be 12Nm.
I removed the flywheel (normally not needed during a clutch replacement) to replace the two rear main seals. I noticed a very slight weep, so I figured since I was in there I'd do that job too.
I got new bolts and noticed that the 6 new clutch housing bolts were a bit longer than the one's that came on my June 00' production S.
MarkC
Old 01-22-2004, 03:48 AM
Those are only 6mm bodies. 40mm is way too high. I"ve never read the figs on that for an oilhead, but older, very similar late-airhed clutches use 6mm bolts too, and call for 20 nm. When reusing bolts, I generally torque to 22. Done it for years. Never a problem.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 01-22-2004, 09:06 AM
