Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > BMW R1100S / R1200S Tech Forum
Dusty's Avatar
Angry Vibration
Hi guys,
Wondering whether any of you have a solution for the vibrations felt between 4-5k. The bike is now 12 months old (single spark) prep. Only engine mod includes a full Staintune system and K&N filter. Any advice would be greatly appreciated!
PS I understand the twin spark ignition fixes this problem?
Cheers,
2003, ABS, Wide rear wheel, Raised screen and bars & heated grips, K&N, Staintune
Old 02-03-2004, 02:33 AM
Nitro's Avatar
did you remove the cat code plug?
Did you get a carb synchronizer like the twinmax?
Nick
Memento Audere Semper
Old 02-03-2004, 02:59 AM
SCOTTinNJ's Avatar
Did it vibrate with the stock cat and cans? Maybe you have a mounting issue with the tunes.
Old 02-03-2004, 03:07 AM
GUS GUS is offline
As scott said check the 2 little black rubbers which sit in the frame,they wear out aloowing the bracket on exhaust to touch frame.Also the boxer engine aint no smoothy,but you probulary already knew that!The vibes can be subdued somewhat as nitro said,throttle bodies sync and try some bosch platnium plugs.These made a big difference to the way my bike ran.
gus
Old 02-03-2004, 03:15 AM
Dusty's Avatar
Thanks guys, My bike has always had these vibrations from new. I checked the cat mtg rubbers when installing the system - they appeared fine. I was told that installing a chip may also sort out the vibes? An FIM chip perhaps - designed for Staintunes?
Old 02-03-2004, 03:20 AM
blakebird's Avatar
They vibrate
It gets better with age
The twin spark does not eliminate it.
Old 02-03-2004, 03:59 AM
Nitro's Avatar
Dusty,
before spending money on a chip, make sure the cat code plug is not there. You can go the cheep way and change the fuel pressure regulator. That is my set up: full two bro, no cat code, K12 reg., no sorkel.
Nick
Old 02-03-2004, 05:20 AM
roger albert's Avatar
Twinspark may help surging. It has nothing to do with vibration. Most vibration comes from the pistons masses, which you can't (economically) do anything about. A bit comes from differences in combustion. You can minimize those with very even valve adjustments, and a good synch.
Good luck
99 R11S w/ BBP, InDuct, Íhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Íhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 02-03-2004, 05:42 AM
Raven's Avatar
Don't ride it between 4 - 5K!
Old 02-03-2004, 06:29 AM
Living on borrowed time!
JonyRR's Avatar
BMW twins vibrate.....period. They shake like a paint mixer on crack, as far as I'm concerned (coming of 25+years on big jap 4-cylinders the first week with my 'S' felt like an old 400 Maico). Proper carb synch, proper mixture, etc, etc can minimize the issue somewhat, but there's still 2 BIG pistons goin' up and down/ back and forth in there....and no balancer shaft (until a few seeks ago, anyway)
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 02-03-2004, 10:53 AM
Ade Ade is offline
Ade's Avatar
carb* sync and 10,000 miles transformed mine
standard set up S Sport, still has a relatively rough patch at 4k rpm but I just live with it.
*there are no carbs but I can't remember what the dealer called it.
Old 02-03-2004, 11:09 AM
Ade Ade is offline
Ade's Avatar
anyway I like to feel the engine turning, feels like something's going on -had a go on a friends ZX12R and found the turbine smoothness a bit disconcerting, especially given how quick it spun up.
My R6, whilst smooth is still a beast.
Some vibes are good - they keep you awake and let you know the engine is on.
Old 02-03-2004, 11:12 AM
pdonnell's Avatar
Take a 12 lbs. bowling ball and chain it to the right jug. BMW forgot the counter balancer on this model to counteract the vibration.
Good News though. The counterbalancer has been installed free of charge on the new R motor coming out.!!
Old 02-03-2004, 11:56 AM
RoundelRider's Avatar
Send a message via Yahoo to RoundelRider
Them things are Throttle Bodies!
My guess would be the change in exhaust system. I have changed mine around a bit (full system/cat eliminator only), and it has a horrible vibration at about 4-5k rpm where I also like to ride. I think Im going back to the full system this week.
John
John
'03 R1100S Prep RIP
Old 02-03-2004, 05:16 PM
s-addict's Avatar
Send a message via Yahoo to s-addict
bowlings coool...............
The universe operates on two governing principles, one is Reason, the other is Rhyme, which is very close to rhythm.
Our culture is fixated on Reason, the Sea is fixated on Rhyme.
Old 02-03-2004, 06:14 PM
Dusty's Avatar
Thanks guys. I'm not clear as to what the Cat Code plug is where it's located, nor the twinmax synchronizer. Do the Australian models have a cat code plug?
Also a suggestion was to repace the spark plugs with bosch platnium. Is there a specific p/n to suit the R1100S?
Cheers,
Old 02-04-2004, 12:18 AM
GUS GUS is offline
Bosch platnium FR 6 DP,These are the best plugs i,ve used in my bike.In my opinion,they made my bike run better.
gus
Old 02-04-2004, 02:09 AM
Kam Kam is offline
Where'd you guys get your twinmax?
Kam
'01 R1100S going bye bye for an 06 1200GS, '02 aprilia RSV mille R, '03 tuono R, Kelly's bar&lounge
how about never, does never work for you???
Old 02-04-2004, 05:46 AM
pdonnell's Avatar
Kam,
E-mail me offline about a twinmax. I've got a practically brand new one (used once) stored away in the garage I can send you.
Old 02-04-2004, 05:56 AM
adventure motogear or Aerostich/riderwearhouse
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 02-04-2004, 05:57 AM
