-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Size of the 'oxygen sensor' nut? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/151900-size-oxygen-sensor-nut.html)
Goines 03-05-2004 08:09 AM
How big, in mm, is the nut on the oxygen sensor on the catalysator? I need to get a spanner that fits but the bike is at home. :/
shovelstrokeed 03-05-2004 08:24 AM
goines
22mm or 7/8" will work.
Ed
Goines 03-05-2004 08:59 AM
Originally posted by shovelstrokeed
goines
Ed
Thanks. :)
Sman 03-05-2004 09:32 AM
How often should that part be replaced?
RoundelRider 03-05-2004 08:37 PM
When it goes bad, or gets "lazy". To get a accurate reading it should prolly get hooked up to a motronic scantool, and hopefully you can read the voltage with a line graph. A meter can be used in some cases (depending on the meter). I havent heard of a milage where they should be changed at.
John
