Have an 03 R1100S with Integral brakes. Installed the Clear Alternatives tail light with the LED bulb. Getting a fault light on the dash. When I reinstall the stock bulb, the fault goes away. Anyone using this product on a bike with Integral brakes? Love the clear look and would like to make it work. Clear Alternatives sent me a replacement LED to try, but no luck. Thanks in advance for any help
Bill Telle Iowa "Not a 2nd childhood, still in the 1st" 2013 F800GT |
Hey;
I have the same set-up but it's on 2000 model no problems, You my have to put an resistor in the circuit. see past posts
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
EZ-RIDER: Thanks for the reply. Integral braking was not an option on the 2000 model. Did a search on Clear Alternatives and found nothing concerning my problem
Hey Wildwilly
Hey;
I know that my abs is different then the set-up you have. I will look for the past post for you
The LED light will not work with integral abs. Need to use the stock bulb in red. EZ-Rider: Quit looking for the past post and thanks for your offer to do so.
Bikes with latest ABS monitor the power going to the rear light and if the standard 5w filiment blows it reduces the power to the 21w stop filiment for normal running so you always have a rear light.
LED lights confuse the power monitoring so dont work. Bern.
Bern |
Living on borrowed time!
And this is just another reason NOT to have all that fancy 'the bike knows better than the rider does' gimcrackery. I wonder how long until there's a FDR (flight data recorder) on these things just like the 'stealth' one in all the airbags of every OBDII-compliant car......
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
Just read the R1200GS has no wiring loom, just one "smart" wire and NO fuses... it's all microprocessor controlled.
Cuts down on do-it-yourself projects...
06 Multistrada 620 04 R1100SA - sold |
WildWilly - I have a 03 as well and have encountered the same issue. I am going to call Robert Foster and see if he knows anything that we could do or possible refund my money.
Szent Thomas 03 R1100SA 85 635CSi |
Regnat populus
ABS Fault W/LED
Greetings,
The LED's do create a fault in the ABS system. If you purchased an LED from me and have a problem, we can resolve this issue. Please e-mail me at the e-mail address below.
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. |
No Info on (t)his member
Just buy ( or make ) a Red bullb, and all will be well.
jeff
_________________________ jeff clark 99 R1100S 82 Alfa Romeo Spider Veloce |
Just a wild guess, but I bet the system is trying to make sense of the current draw. Try measuring the current through the original bulb and the new set (use a low-value resistor in series, measure the voltage drop across it), and then calculate what will be needed to be added in parallel with the new one (I'm guessing that the new ones, using LEDs, are probably drawing less) to make it emulate the old bulb.
Don't try to measure the resistance of the bulb(s) directly - it varies greatly with temp. in the incandescent, and your meter probably won't push enough voltage and current to make the LEDs conduct. Just a guess... Mike |
