Barback King
Installing full set.
Started on rear and I see that the male end of the brake line does not thread in all the way to flush with the female receiver like the OEM "collared" rubber brake line. Is this just a compression fitting? Do I just tighten in to snug at this end? Torque recommend is 18-22 NM in the instructions. There are 3 aluminum crush washers included. I assume that there is an extra and that you use 2 of them on the bango end of the brake line only. Correct? To recap, use crush washers on banjo ends only. Please confirm Thanks,
R11S CNC BARBACKS |
No Info on (t)his member
That's how I did it.
You may also call Spiegler - they are happy to help. jeff
_________________________ jeff clark 99 R1100S 82 Alfa Romeo Spider Veloce |
RD, I thought the same thing when I did mine when threading in the rear line. The rear line (non banjo end) threads in and will bottom out against the internal pressure fitting. Looks odd, but that's how that end works, so don't use the aluminum crush washers on it. The crush washers are to be used on the banjo portions of the lines only (one one either side). Any extra crush washers can be thrown over your left shoulder after making a wish. One tip I would give, is make sure when you refill the front reservoir and replace the rubber diaphram, you clean off any extra fluid that be forced out and on to the edges of the reservoir. That way when you get up to speed this bit isn't blown all over...
Regards, Sirus |
Talking with the Techs at Galfer recently I was told never to fill the reservoir more then 3/4 full when using stainless lines. If you don't have an air space for expansion when the fluid gets hot the pistons in the calipers can't retract. He claims they see this all the time at the track. How are you guys routing the left side front line around the telelever. Got a pic?
John B. 03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5 90 535im & 95 525i Touring 65, 66 Alfa Romeos |
The set that RD has, comes with its own "T" for the front (mounted on the rt fork) and you reuse the steel fixed line present, to span either side (so that remains). This isn't a dual banjo if that's what you are asking? The front system, is composed of 3 braided lines...
Regards, Sirus |
OK, the set up I have for my wife's Prep from Galfer consists of two long lines with the dual banjo. Just wondering what others have done with the second(left) line to keep it looking clean & out of harms way.
This is how mine is setup.
Lever Travel with Fully Bled Brakes - How Much?
2003 R1100S BCR 1995 CBR 400RR (NC-29) 2002 Honda XR400 R 2004 Yamaha TTR 125 L |
Yup that's the 1 into 2... Jeff Williams has the dual setup pics here.. Install tips for Spiegler SS lines ?
Regards, Sirus |
Barback King
Thanx guys.
All going well.
R11S CNC BARBACKS |
77 R100RS95 A6 Quattro http://www.joesrepairshop.com/ |
Thanks for the pics/links guys. I hope to install the hoses & KRS bars this weekend.
John B. 03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5 90 535im & 95 525i Touring 65, 66 Alfa Romeos Last edited by bikpaintr; 04-10-2004 at 06:05 AM.. |
Rapido,
You shouldn't be messing with something that came from the factory flawlessly engineered. Unless your trying to keep up with the glitzawitz crowd. Best,
