acidburn's Avatar
R1100S, bigger gas tanks
anyone have this dialed in?
I know there was some talk of custom mods etc, im up for it, need more go juice on board.
With the new diablos on this biek it is truly a dream ride.
Except for a few cases the murderCycle rate is relatively low on this board, keep up the good numbers.
Old 05-28-2004, 11:21 AM
On the topic of gas tanks. I was suprised to find that the Ducati MH900E only has a 2.2 gallon tank! Range is said to be 90 miles. I want one so bad, but couldnt see 90 mile tanks being very fun..
Now back to your normal BMW content.
Matt
RIP Jeff Williams; RIP Brad Zimmerman
1989 K100RS - White/Blue, Remus; 1999 R1100S - Mandarin Orange, Remus, Ohlins; 2007 G650XCountry - Black/Silver, iStorm Luggage - Wilbers 75mm Lowered shock for the wife!; 2003 BCR #57 - Jeff's bike ; 2009 G477X - Akrapovic, WP Trax, SpeedBrain Goodies
2000 ///M5 - Custom Black & Blue, Dinan goodies
Old 05-28-2004, 11:30 AM
Moybin's Avatar
You want
Aux Fuel Tank
More than enough info there. In simple terms, no aftermarket unit available to increase tank size, as there is for the R11xxGS.
'99 Black SA "OBSSSN" - gone but not forgotten.
Not all good technology is new, not all new technology is good.
.........Purple is Satire.........
Old 05-28-2004, 12:01 PM
Here you go. 1.15 gallons for non ABS R11S. $275 plus $10 shipping. If you vent the filler neck on the main tank and add this tank you should end up with about 6.2 to 6.3 gallons.
Philip
03 R1100S BCR #44
Staintune
InDuct
SJ PowerFilter
FIM Chip
Ohlins
Throttle bodies matched to rubber mounts matched to heads
Exhaust pipe welds ground down
Old 05-28-2004, 12:18 PM
acidburn's Avatar
very nice, however i have ABS, hmmm i have bags too maybe i need to think about 2 qt dirt bags aux bottles in the bags, dam that is a nice set up, good work.
Ill just need to see how they set up the new k1200s before i throw more money at my beloved donkey bike, too bad the ole lady wont let me sell it under any condition.
Old 05-28-2004, 02:11 PM
If you have a good sheet metal fabricater in your area your stock tank can be enlarged to approximately 7 gallons. There have been several people to post info in the last 4 years. I have enlarged my non ABS tank to 5.9 gallons with a 3 inch ram air pipe run through it. Eddy
Old 05-28-2004, 04:35 PM
acidburn's Avatar
bigger tank sounds tastee it will be off the bike next week for a sender upgrade, maybe thats the way to go.
Old 05-28-2004, 04:39 PM
Where in the heck are you going to find room for 2.2 additional gallons on an ABS bike? I'd love to the see the posts with that info.
- Mark
Old 05-28-2004, 05:22 PM
EMCCARTY,
Very true but as I recall there are only a few fabricator, that work with gas tanks, that are willing to do it and the cost was in the $400 to $500 range. Don't forget the down time. I didn't want to spend that kind of money and possible ruin a perfectly good tank. So I came up with this solution. Less expensive and only an afternoon to install. With my 1.35 gallon tank (not for production) and the modified filler neck, on the main tank, I was able to squeeze about 6.8 gallons into the 2 tanks. So I figured with the 1.15 gallon aux tank you should be able to cram about 6.5 to 6.6 gallons into both tanks. If you have the money and can find a competent fabricator to do it then go for it. I think it would be a better solution if cost and down time were not a factor.
Philip
03 R1100S BCR #44
Staintune
InDuct
SJ PowerFilter
FIM Chip
Ohlins
Old 05-28-2004, 06:45 PM
