idle adjust...simple but never done it
recently the S has been idling a tad low, thus a tad rough. it runs great, smooth, etc. but seems to sit at 900RPMs at idle. normally it starts lows and then rises to about 1100. i thought that humidity might play a big part as i notice a difference in engine feel depending on humidity. aside from all that...how do you adjust the idle? i am askign the question even though i will check the shop manual and all. and i will more than likely grab the twinmax to check out the TB's.
repoe3 |
repoe,
you should find the answer here: http://www.advrider.com/Wisdom/TBS4Dv1.0.pdf other good tech stuff here: http://www.advrider.com/Wisdom/Wisdom.html |
thanks...maybe i will tackle that this weekend.
repoe3 |
| All times are GMT -8. The time now is 06:16 PM. |
