Dingo Joe's Avatar
K12 fuel pressure reg INSTALL
I've a '99 R1100SA, motor is stock except for a 2BR cat elim. I've noticed that the bike now no longer runs rich, ie. My exhust pipes no longer get sooty. The bike runs very well, smooth, No ping/surge(never did), runs balanced and gets around 41-43 mpg, which it always got. I'm thinking about adding a K12 Fuel Pressure Regulator to the mix, just to ensure I do not end up to lean and burn up a piston.
First off, should I be worried about this, is me engine going to go boom?
Secondly, the install instructions for the K12 reg on an ABS equipped bike say to remove both the ABS unit and the Motronic unit, then the battery tray just to get to the fuel regulator. Perhaps I should remove the transmission just for good measure?! Is there an easier way to do this wit out taking so much stuff off the bike?
thx for you help....
Old 07-14-2004, 05:37 AM
Joe Joe is offline
Joe's Avatar
Send a message via ICQ to Joe
First if the bike is running OK and no pining I would leave it alone your mod of just a cat eliminator doesn't warrant a 8% increase in fuel.......if you added the San-Jose Power-filter then I would recommend it. IMO & experience.
If you want to be absolutely sure get a dyno run with a gas sniffer.
Sorry can't help you with a shortcut other then get rid of the ABS.
77 R100RS95 A6 Quattro
http://www.joesrepairshop.com/
Old 07-14-2004, 05:46 AM
roger albert's Avatar
Ditto all non-dingo-Joe's comments.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 07-14-2004, 05:55 AM
Dingo Joe's Avatar
well, coming from you 2 guys, i feel a little better aboot the situation, thx...
Old 07-14-2004, 06:10 AM
No Info on (t)his member
jclark's Avatar
No easier way - remove the ABS unit, the battery tray, and try not to crack the airbox. Don't remember if I removed the brain box... but can't see why one would.
Well, if it's in the way, duhh. But I don't recall that being the case.
Pop new regulator in, and, taa daa.
jeff
you may drop an itsy bitsy bit of gas milege too..
_________________________
jeff clark
99 R1100S
82 Alfa Romeo Spider Veloce
Old 07-14-2004, 07:57 PM
I didn't completely remove the ABS unit. I remove the bolts and rocked it forward to reach the battery tray bolts. It was a *****, but do able. BTW I am getting 45-48 mpg. With remus, sj power filter, k12 reg and induct
Old 07-15-2004, 06:20 PM
Dingo Joe's Avatar
Thx Davidb2, I was hoping someone would say that this method would work. I had the same thoughts myself and was close to attempting myself. How long did it take you?...
Old 07-16-2004, 05:26 AM
about 2 hours
Old 07-16-2004, 09:18 AM
