Haven't ordered any shims, but will if what we have doesn't work. |
the round gear is worn, which means I have to replace the rest of the gears. I'm replacing the gasket, but the seals all look good.
Describe the 'round gear' to me. The pinion is the one connected to the driveshaft. It's got 11 or 12 teeth. The ring gear looks like a ring and has around 33 teeth. Attached, and part of that gear, are the splines that mate to the splines in the rear wheel hub. Generally the ring and pinion don't wear. Just the splines. Are you saying that the ring gear is worn? Could you post some pictures of this part and the wear? I'm really curious since I haven't ever seen a bad one, or even heard of one of these going bad. I may have, but it would have been so long ago I don't remember. |
exactly my thinking tvrla. I've only seen them bad twice, both with bone dry rear housings. Even then they only seemed chewed up by bearing debris. This is really odd.
Yes. Quote:
What do you figure caused the damage?
not sure.... I've never even started it up. The previous owner might have neglected oiling the final drive.
| All times are GMT -8. The time now is 06:01 PM. |
